Closed Thread
Old 07-03-2004, 10:49 PM   #1
auxmike
auxmike is on a distinguished road
auxmike's Avatar
Wrench Changing the ECTS Coolant Temp Sensor (with pictures)
This is how I changed my coolant temp sensor in a 1995 SL2 Twin Cam with auto tranny and ABS.
I bought the sensor from a Saturn dealer,this way I got the special threadlocker on it already to install.I would not buy an aftermarket version of this part because of this.
DISCLAIMER!:I just took pictures of what I did one day.
I don't suggest you actually try this at home yourself.Hire a real mechanic.I am not responsible if you try this and get hurt or ruin your car doing this!
First I made sure the car is DEAD COLD!You can't do this with hot antifreeze,it will burn a guy badly!
BEWARE THE AIRBAG SENSORS!:
If I have an older Saturn I would notice two stickers on the black metal front frame.I don't bang stuff there!
Ice cold engine off , I opened the hood.
I unclip the 4 airbox clips by the radiator end of the intake.
I Squeezed together the two prongs of the spring clip that holds the intake to the throttle body.
It locked open to allow removal from the throttle body.That clip stays on,BTW.
I removed the breather hose from the valve cover.Then remove the plastic intake.
I Found the ECTS under the EGR valve.Some cars have two sensors,it's the lower back one I could not even see.I had to feel for the two "high" spots on the connector bell and squeez/pull to get it off.See below later on details how this is done.
Add to auxmike's Reputation
Rate the quality of this post and help auxmike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
auxmike is offline
Old 07-03-2004, 10:50 PM   #2
auxmike
auxmike's Avatar
Default
After I got the connector off,this is how it looked in the car.I could'n't see this so I stuffed the camera in there.
I used a 13mm deep socket to unscrew the old sensor,1/4 inch drive preferred.I didn't unscrew it all the way though!
I quick unscrewed the connector the rest of the way by hand,then had the other new sensor in hand ready to screw in.Coolant WILL come out of the hole,so the quicker I got that new one started ,the less a mess I had.Note the red stuff on the threads.That's the VERY important threadlocker that comes on the dealer part.
Tightened down the new sensor with the 13mm socket.Spec is 71 INCH pounds,that's not a lot!I did not overtighten,but didn't leave it so it will wiggle out later either.
I just turned it till it felt snug enough to stay put.Their is threadlocker on the dealer part sensor,red stuff.
auxmike is offline
Old 07-03-2004, 10:52 PM   #3
auxmike
auxmike's Avatar
Default
I Checked old sensor and connector.If the connector is slimey inside,one might want to buy a new one.This is optional,but recommended if one has green slime in connector.
Here's the connector pack I can buy from the dealer,cost $26,comes with instructions.
Here's new all brass next to old cracked brown resin ECTS.What's that PCV valve doing in there?
This is how the sensor goes in/out.I squeeze it on the black just above where my thumb is.I did'nt squeeze the longer "horns".They are part of the locking system.This is the sensor resting in position.
auxmike is offline
Old 07-03-2004, 10:53 PM   #4
auxmike
auxmike's Avatar
Default
This is the sensor locked in.Note how the "Flats" on the brown part lines up with the black part you squeeze.
I couldn't see any of this,so I had to feel it to get it back on right,the connector that is.
Thus the illustration outside of the hidden area it resides in.
Once the sensor is in and connector reattached,reinstalled the intake.
I gently squeezed again the spring clips at the throttle body while pressing down the lock tab with a screwdriver.Eased off the clips gently.
Pressed closed the 4 clips for the airbox.
Checked the antifreeze level,topped off if needed.Checked for any tools left around engine bay or hood!
Started car,checked for any leaks.
This is what I did today,thought you might like to see.
Remember,this is show and tell,I'm not teling you to try this yourself.
auxmike is offline
Old 07-04-2004, 10:46 AM   #5
HomeBase
HomeBase is on a distinguished road
Default
THANK YOU!
I need to replace mine on my 96 SL2. This will help me tremendously!
THANK YOU! THANK YOU!
GREAT JOB!!!!
Add to HomeBase's Reputation
Rate the quality of this post and help HomeBase reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
HomeBase is offline
Old 07-04-2004, 11:00 AM   #6
Tiger
Tiger is a jewel in the roughTiger is a jewel in the roughTiger is a jewel in the rough
Tiger's Avatar
Default
Beautiful! Thanks for the great picks and directions!
Add to Tiger's Reputation
Rate the quality of this post and help Tiger reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tiger is offline
Old 07-04-2004, 05:02 PM   #7
dcp
dcp is on a distinguished road
dcp's Avatar
Default
Very good information,THANKYOU!
Add to dcp's Reputation
Rate the quality of this post and help dcp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcp is offline
Old 07-04-2004, 08:00 PM   #8
wolfman
wolfman's Avatar
Default
Very good pictures. I will only interject that the sensor with the SINGLE yellow wire going to it that IS visable in all those pictures is NOT the ECTS. That is the sensor for the GAUGE in 95' and earlier cars. If you look at the picture where the poster is using the ratchet wrench with the extension on it, it kinda points (as he is tightening it in the picture) to where the ECTS IS, BELOW and to the RIGHT of where the one wire gauge sensor that can be seen in the pictures is located. 96' and UP cars will NOT have the gauge sensor visable in these photos so there is no chance of making an error and removing the wrong one.
Add to wolfman's Reputation
wolfman is offline
Old 07-04-2004, 08:13 PM   #9
auxmike
auxmike's Avatar
Default
Thanks Wolf!
Yes,it's the two wire.I would hope folks would realise that by the way I mentioned you can't really see it.
Any advice just how tight to go for the 99% of people out there who don't have a torque wrench in inch lbs.?
I don't like to hammer it all the way home due to the fact it's brass and dished at the end.When I feel resistance,I ease up on it.The threadlocker seems to hold it still quite well.
auxmike is offline
Old 07-04-2004, 08:52 PM   #10
wolfman
wolfman's Avatar
Default
The "feel" of a fully seated ECTS is very similiar to a spark plug. When you feel the resistance increase to the point that you can no longer turn it by hand, THEN carefully use the socket wrench to continue. When you feel a marked increase in resistance to turning the wrench, about another 1/2 turn MAX will do. DO NOT wrench it down with all your strength. You can also pull off the socket and feel for the gap between the hex head of the sensor and the engine. When that gap is gone, the sensor is fully bottomed. I wish your excellant pictures had been added to the "How To" instructions I had posted months ago...they would work quite well hand in hand, though your instructions are right on the money.
wolfman is offline
Old 07-04-2004, 09:03 PM   #11
auxmike
auxmike's Avatar
Default
Wolf,feel free to "steal" my pics and add them to your description as you see fit.Not a problem.
All I ask is credit for the pics.
Mi casa es Su casa!
auxmike is offline
Old 07-22-2004, 06:01 PM   #12
Spazie
Spazie will become famous soon enough
Spazie's Avatar
1993 SC2
Default
I feel handy!! I just did this all by myself. First time I've ever done something mechanic-ish on my car without my brother's supervision. Thanks for the pics, they were a great help!!
13 Chevy Equinox, 46k, built in Spring Hill!
04 VUE 3.5, 196k
99 SL2 Homecoming, 211k
Add to Spazie's Reputation
Rate the quality of this post and help Spazie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Spazie is offline
Old 09-15-2004, 11:23 AM   #13
Razorbak
Razorbak is on a distinguished road
Razorbak's Avatar
1996 SL2
Default
ttt
Can one of the moderators please make this thread a sticky?
(Same for wolfman's ECTS thread.)
Thanks.
Add to Razorbak's Reputation
Rate the quality of this post and help Razorbak reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Razorbak is offline
Old 09-19-2004, 05:56 AM   #14
ndsaturn
ndsaturn is on a distinguished road
Default
quik question. the etcs on my 93 saturn is brass with a black plastic end. which one is this? old or new style, or aftermarket ? ty
Add to ndsaturn's Reputation
Rate the quality of this post and help ndsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ndsaturn is offline
Old 09-19-2004, 02:06 PM   #15
sierrap615
sierrap615 is on a distinguished road
sierrap615's Avatar
Default
thats the new and improved style.
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
Add to sierrap615's Reputation
Rate the quality of this post and help sierrap615 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sierrap615 is offline
Old 12-14-2004, 05:39 AM   #16
123SVT
123SVT is on a distinguished road
Default Re: HOW OT: Change the ECTS Coolant Temp Sensor w/pics!
I tried this BUT at the last step I couldn't get the conector on right now it read nothing on my temp gauge....
Ryan
Add to 123SVT's Reputation
Rate the quality of this post and help 123SVT reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
123SVT is offline
Old 12-15-2004, 03:08 AM   #17
sierrap615
sierrap615's Avatar
i know it doesn't look directional, but i'm sure it is, try fliping it 180 degrees
Old 12-15-2004, 11:52 AM   #18
Luke
Luke's Avatar
Default Re: HOW to: Change the ECTS Coolant Temp Sensor w/pics!
Spazie
That should strongly support the suggestion that you continue to work on your car--it can only gett better, & surprise you even more.
Add to Luke's Reputation
Rate the quality of this post and help Luke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Luke is offline
Old 12-15-2004, 08:53 PM   #19
emptypockets
emptypockets is on a distinguished road
emptypockets's Avatar
1999 SC1
Thumbs Up Re: HOW OT: Change the ECTS Coolant Temp Sensor w/pics!
Awesome auxmike! I need to do this on my car and I don't think we even have a 13 mm socket let alone a deep well. Thanks for the how-to.
Add to emptypockets's Reputation
Rate the quality of this post and help emptypockets reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emptypockets is offline
Old 01-29-2005, 10:31 PM   #20
green
green is on a distinguished road
Default Re: Changing the ECTS Coolant Temp Sensor (with pictures)
Auxmike:
In the photo with the ratchet it shows one end of the connector (black cap cover) going to the sensor, where's the other end going? My 95 SW1 temp gauge isn't working. The photo with the part in the bag is exactly (with 2 butt connectors) what I bought from Saturn but they give me instructions.
Could you give me instructions (photos?) on how to install the connector.
Thank You very much.
Add to green's Reputation
Rate the quality of this post and help green reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
green is offline
Closed Thread
Changing the ECTS (Engine Coolant Temp Sensor) wolfman How-To Library 93 11-07-2005 12:58 PM
ECTS and Temp Gauge Sensor Wiring WingsOfSaturn S-Series Tech 7 10-22-2005 10:45 PM
Ref Mike's "How-To" : Change the ECTS Coolant Temp Sensor w/pics! Luke S-Series Tech 2 06-20-2005 02:19 AM
Does anyone now if the sensor on the transaxle is the same as the coolant temp sensor BigDaddyDrex1 S-Series General 4 05-27-2005 03:29 PM
Here's my famous cracked Coolant Temp Sensor Scan {ECTS} auxmike S-Series Tech 36 01-30-2005 02:17 PM
