Old 08-19-2003, 02:59 AM   #1
Maritime Storm
Maritime Storm has a spectacular aura aboutMaritime Storm has a spectacular aura about
Maritime Storm's Avatar
2003 ION-2 Sedan
Default Misfire after Changing Plugs???
Got's a question for youse? I have a 2001 SL, just hit the 50,000kms mark, time to change the plugs right. I went to my local Canadian Tire, the carried 2 brands of plugs Champion & Bosch Platiniums. The carry NGK Platinium plugs but didn't list a set for my car???{Saturn OEM is NGK}. So I figure I'd spend the few extra dollars & get the better plugs. Tonight coming to work I noticed I slight bit of misfire on acceleration. {Side note I've put 1000kms of Cape Breton Highland torture on the car since I changed them & didn't notice any misfire} Here's the question anyone else notice getting a mild bit of misfire after changing to Bosch plugs? Should I pull em out & get the Champion plugs or is it possible that they may have gotten slightly glazed after it's "workout" on the weekend?
Save the Earth, Ban Slushboxes!!!!!
Add to Maritime Storm's Reputation
Rate the quality of this post and help Maritime Storm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Maritime Storm is offline
Old 08-19-2003, 07:43 AM   #2
bennett9000
bennett9000 has a spectacular aura aboutbennett9000 has a spectacular aura about
bennett9000's Avatar
Default
Some Saturns don't like platinum plugs. Plain ol' NGK's are the best.
Is there a chance you got your wires crossed?
-Andy
01 SL1 (2011-2014) 99 SW2 (2002-2009) 95 SL2 (1997-2002)
00 ROUSH Cougar V6 03 SVT Focus #2370 08 Mustang Bullitt #5389 2013 Fiat 500 Abarth
Add to bennett9000's Reputation
Rate the quality of this post and help bennett9000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bennett9000 is offline
Old 08-19-2003, 06:37 PM   #3
Dach
Dach is a jewel in the roughDach is a jewel in the roughDach is a jewel in the rough
Default
I know your wires aren't crossed but the platinum plugs are problematic in Saturns. Get the ngk's and see if there's a diff. How's your valve cover gasket? Do you see any oil in the plug holes? That's another common problem that causes misfires.
Add to Dach's Reputation
Rate the quality of this post and help Dach reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Dach is offline
Old 08-19-2003, 07:11 PM   #4
Saturn-Eh!
Saturn-Eh!'s Avatar
Default
Hop on down to Moncton Saturn Saab Isuzu, and pick up a set of the original NGK's If that is a touch too far, have them give you the number to source locally, or have them ship to you.
Check also the wires and coil towers for any type of corrosion - and replace the wires as a set if you find any.
Saturn's (especially 96 and up) tend to be finicky about ignition parts. If you use OEM, and make sure the coils are ok, then you can't go wrong.
Add to Saturn-Eh!'s Reputation
Rate the quality of this post and help Saturn-Eh! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturn-Eh! is offline
Old 08-20-2003, 01:36 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
Default
remove the platinum plugs and put regular ones in.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 08-21-2003, 01:17 AM   #6
Maritime Storm
2003 ION-2 Sedan
Default
Thanks for the help guys. The car has been working fine the last 2 days, may have been a bad tank of gas. If I have any further problems I'll drop down to Moncton Saturn{3kms from my front door} and get some NGK's. I've always used Champions for years in my Fords & Chryslers without problems, should have gone that route at the time I guess. I found it odd though that they didn't list NGK's at Canadain Tire{NGK makes Canadian Tire's house brand for spark plugs}. I figured at the time I'd spend a couple of dollars more for the "better" plugs.
Old 08-21-2003, 02:00 PM   #7
racerdain
racerdain is on a distinguished road
racerdain's Avatar
1993 SL2
Default
Chances are the NGK book didn't show them. The actual NGK numbers are as follows. Single cam: BKR4ESA-11 Dual cam:BKR5ESA-11, you should be able to get them through a decent parts store who doesn't mind trying, with those numbers.
Mike Moore
Saturn of Tiffany Springs
Parts Manager
Add to racerdain's Reputation
Rate the quality of this post and help racerdain reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
racerdain is offline
Changing spark plugs gordonwd S-Series Tech 43 01-02-2012 01:01 AM
replaced spark plugs now cylinders misfire BGroth S-Series Tech 1 10-31-2009 01:34 PM
04 Vue - Changing the plugs Vue Daddy Vue Tech 9 05-11-2008 07:47 PM
Changing plugs (97 SL2), oil on plugs blueelvis S-Series General 5 04-20-2006 07:09 AM
Changing my own plugs Admiral Beez S-Series General 6 11-10-2005 10:55 AM
