Old 12-18-2005, 01:33 AM   #1
tech kjr
tech kjr is on a distinguished road
Dizzy trans swap
I reasonly purchased a 95 SL1 with a bad trans(no reverse) I replaced it with a junkyard unit out of a 94 SL1 and at first it shifted then it went into what I think was Fail Safe,the service soon light came on and it stopped shifting.I got another used unit from a 96 twin cam and the exact same thing happen.I was thinking of trying to swicth the valve body from the 94.Please Help.
Add to tech kjr's Reputation
Rate the quality of this post and help tech kjr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tech kjr is offline   Reply With Quote
Old 12-18-2005, 12:28 PM   #2
eljefino
eljefino's Avatar
1995 SW1
Default Re: trans swap
neither will work. read http://www.turbosaturns.net/forum/viewtopic.php?t=2211
you should shop at a junkyard with a hollanders interchange.
You MUST keep automatics matched to their motors, SOHC to SOHC and vice versa. They have different ratios and the computer will complain.
95-02 trannies are the same (from what i read on this site, double check) as long as you match motors so your 96 twin cam won't work.
94 is a different animal so despite it being sohc it won't work.
If you just want the car to move now with minimal effort you could try running the 96 twin cam computer but you'll have a check engine light due to no rear o2 sensor and you'll have to swap injectors and some other stuff. The ignition timing curves are off a bit between sohc and dohc but again, from what i read, the car will run. The frankenstein you create will have a short top gear and that'll buzz the sohc motor and waste gas.
sorry you're going through all this work.
Add to eljefino's Reputation
Old 12-18-2005, 12:33 PM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
Actually 95-97 SOHC autos are the same. Those can be interchanged. Putting the 94 valvebody into the 95 transmission will cause the same problems.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 12-20-2005, 12:56 AM   #4
tech kjr
Thank you guys for all of your info and input I really appreciate it,what do you guys suggest I do at this point? Should I just try building the orignal unit that had no reverse? And if the valve body in the 95 SOHC unit is no good can I use the one off the 96 DOHC and just change the electrical connector on top of the vavle body?
possible trans swap 1st time buyer Vue Tech 3 06-11-2007 07:24 AM
96 SL1 w/ MP7 TRANS??? PLZ HELP!!! SWAP PCM FROM DOHC???? SWAP BOARDS??? randyshear S-Series Tech 20 11-15-2006 05:58 PM
Trans swap Tom Mohr S-Series Tech 11 06-30-2005 09:01 PM
Trans. Swap rrharmon S-Series General 20 05-24-2004 09:19 AM
Trans. Swap rrharmon S-Series Tech 2 03-01-2004 09:27 PM
