Old 11-02-2018, 06:28 PM   #1
ddemier7
ddemier7 will become famous soon enoughddemier7 will become famous soon enough
ddemier7's Avatar
2004 ION-1 Sedan
Heart Will a 2005 2.2 swap to a 2004 2.2?
Hey guys will a 2005 (mfg date 11/2004) automatic 2.2 sedan swap into a 2004 2.2 ion level 1 automatic sedan with no compatability issues? I think the 2006 and up 2.2 wont swap into the 2004 ion sedan with no compatability issues.
I found a spare engine in the salvage yard with 22814 miles on it. VIN# 1G8AL52F45Z130063
Add to ddemier7's Reputation
Rate the quality of this post and help ddemier7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-02-2018, 07:21 PM   #2
19boneatock88
19boneatock88 is on a distinguished road
2004 ION-2 Sedan
2006 ION-2 Quad Coupe
Default Re: Will a 2005 2.2 swap to a 2004 2.2?
The long block should swap in... you need to use the intake/exhaust manifolds from the 2004... did the 2005 car have secondary air injection?
Jerama- WV
2004 Saturn Ion-2 sedan
L61/F23(M86), 139k...
Too many mods to list in sig...
“Stock” is nowhere in my vocabulary...
Add to 19boneatock88's Reputation
Rate the quality of this post and help 19boneatock88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
19boneatock88 is offline   Reply With Quote
Old 11-03-2018, 12:44 PM   #3
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
good question about the secondary injection . How or what would I look for to find out if that engine is equipped with secondary injection?
Old 11-03-2018, 01:12 PM   #4
19boneatock88
2004 ION-2 Sedan
Easiest thing to find that signals secondary air injection is the extra hose from the airbox...
I don’t know if it would make the head incompatible with a 2004 that didn’t have it, but I know that some(or maybe most/all) 2004s didn’t have it and therefore don’t have the electrical connections to run it... same with the electric TB and the MAF sensor
Both cars being automatic brings up an interesting thought... are the flexplates the same? The 2004 automatic sedan used the AF23 trans and the 2005-up used the GM 4T45E...
Jerama- WV
Old 11-03-2018, 03:19 PM   #5
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Thumbs Up Re: Will a 2005 2.2 swap to a 2004 2.2?
Good thinking on my 2004 Ion, I have the Asian Af23 transmission. i would have to run the donor car VIN# and see what transmission it was equipped with.
Old 11-03-2018, 04:19 PM   #6
19boneatock88
2004 ION-2 Sedan
The 05-07 cars all use the GM 4T45 trans...
Jerama- WV
Old 11-05-2018, 11:19 AM   #7
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Dizzy Re: Will a 2005 2.2 swap to a 2004 2.2?
Does the 4t45 transmission interchange with the asian transmission with no modification what so ever? direct bolt on and go including converter and fly wheel?
thanks for the info.
Old 11-05-2018, 12:20 PM   #8
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
The answer is a solid no. They are completely different transaxles.
2007 Ion 2 Quad Coupe 5-speed manual 180K miles
2007 Chevy Equinox LT 191K miles
2018 Chrysler Pacifica Touring L 27K miles
Add to ruley73's Reputation
Old 11-06-2018, 10:13 AM   #9
19boneatock88
2004 ION-2 Sedan
The 4T45 will bolt into your car provided you use the correct converter and flexplate, HOWEVER your car isn’t wired to run the 4T45... would have to make significant wiring changes to make it work...
Unless your AF23 is failing I don’t see any good reason to attempt to 4T45 swap your car, unless maybe you were racing and needed a trans which would take a higher power output (the 4T45 can be built to take around 450whp)
Jerama- WV
Old 11-09-2018, 02:24 PM   #10
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Heart Re: Will a 2005 2.2 swap to a 2004 2.2?
Thanks for letting me know on that wiring. im looking for a plug and play fit. to bad cuz that a low milage donor car. but not worth all the headaches to rewire and diag.
Old 11-13-2018, 02:38 PM   #11
19boneatock88
2004 ION-2 Sedan
Don’t get me wrong, the engine itself is nearly a plug and play for and if you take time to swap your intake manifold over to use your stock cable TB it is (provided it doesn’t have SAI) but the trans isnt
Jerama- WV
Will 2005 2.2 fit in Ion 2004? bdelacruz Ion Tech 2 04-18-2012 10:11 AM
2004-2005 Ion MP3 radio to 2000-2002 S-series swap southaeastpunk S-Series Mods 0 04-08-2011 10:18 PM
2004 and 2005 SL2 - RWD or FWD? bsc33 S-Series General 5 01-06-2010 11:22 AM
2004 2005 Cvt Troy Vue General 31 12-20-2006 04:38 PM
2004 and 2005 ...are they the same?? Idouoooo Ion General 3 11-02-2005 11:33 AM
