Old 03-30-2018, 06:29 PM   #1
Nigey
Nigey is a jewel in the roughNigey is a jewel in the roughNigey is a jewel in the rough
2007 AURA XE
Default Saturn Aura reliability? And $2K to replace the y-pipe?
Well, this is really annoying. I just had the gasket replaced between the y-pipe and exhaust after it started blowing, and the guy at the store showed me the condition of the y-pipe. Looks like I'll be needing a new one fairly soon.
However, while you can get to the bolts, the real issue is removing it once it's loose. How do you remove it? By removing the sub frame or lifting the engine of course! This was quoted as $2,000 to me. Usually these guys are decent, so I tend to think this price is in the ball park.
Which idiot designed it that way? I'd like to give them a piece of my mind. I've had my 2007 Saturn Aura with 60K miles for approximately 15 months now. In that time it's done 7K miles at a cost of:
$1200 to replace steering rack
$350 front wheel bearing
$30 signal stem
..and messing around to get the 3rd brake light working.
And it looks like if I want to keep it on the road, I'm more than likely looking at another $2K pretty soon.
Saturn Aura? No thanks, never again. I'm really thinking of trading it in for another car while it doesn't sound like a sports car, sometimes you just take a loss.....
2007 Saturn Aura XE 3.5 L LZ4 V6
2002 Saturn SL2 1.9L (manual)
Add to Nigey's Reputation
Rate the quality of this post and help Nigey reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nigey is offline   Reply With Quote
Old 03-30-2018, 09:50 PM   #2
Default Re: Saturn Aura reliability? And $2K to replace the y-pipe?
I'll bet a good muffler shop worth their weight in welding and customizing exhaust systems can probably create a replaceable 'Y' pipe for far less than $2k without dropping the subframe..... Skills and thinking outside the box. You have to either call around or visit shops to find the right one so the person that can do the work can see the challenge and figure out a way for less than what book procedures (GM) say.
I can imagine your frustration and may have at least one idea in mind but since I'm not an Aura expert or familiar with exhaust systems, it's easy to conjure up a solution but without seeing a picture or two of your system, its guessing. "Where there's a will there's a way..." There's always a solution than the one presented.
Old 04-03-2018, 06:18 PM   #3
mmtphoto
mmtphoto is a jewel in the roughmmtphoto is a jewel in the roughmmtphoto is a jewel in the rough
mmtphoto's Avatar
2007 AURA XR
I agree with FDryer, and the other prices (except for the turn signal multi switch) are pretty high-$350 for a wheel bearing hub? that is crazy IMO...Same with the steering rack, it is really not that big of a deal to do in a garage with floor jacks and a few hours.
Any good exhaust shop can fix or replace an entire exhaust, and very complicated I'll add, for substantially less than $2000 (not including the expense of a cat, of course, which is still managable if you can be open to going non-OEM).
Consider getting other opinions. While a good mechanic is hard to find, it is still an open economy and there are other ways to skin a cat.
I do mostly all my own work, but if I have to get something done that I am not equipped to do, I have multiple contacts locally so I do shop around. Best not to over react to one outrageous estimate-do some homework, it might not be as bad as all that. Good luck.
Add to mmtphoto's Reputation
Rate the quality of this post and help mmtphoto reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mmtphoto is offline   Reply With Quote
Old 04-03-2018, 09:06 PM   #4
Nigey
2007 AURA XE
Yes, the wheel bearing was a mistake; I'd been bringing cars to a local place that had been pretty good and charging fair prices. When the wheel bearing went, I made a *BIG* mistake of not looking it up myself and assuming I'd needed a press (which I don't have) which it doesn't need. I was definitely rucked on that one and when I saw the bill, I was surprised! The same place (interestingly it had a new manager so I should have been more careful) also wanted $2,000 for a replacement steering rack, but I'd already had my suspicions by then, and went to another place that did it for the $1,100. Sadly, after 20 years of using this place, it's off the list now for me.
Also, keep in mind the steering rack went when it was cold -really cold -weather, and I don't have a garage or lift. Yes, I could have done it myself, but I really didn't want to mess around in the cold on an icy driveway -plus at the time I needed the car to get into work and would have only had a weekend to do this in. I'm also going to add I don't think this job is just a couple of hours (at least for me, and I did contemplate doing it myself.)
The issue with the y-downpipes (that have a cat as well as the one at the back) isn't the undoing of it, it's the removal and replacement that is the problem. Look underneath and you'll see there isn't the space to remove or insert it without the engine or sub frame moving (sigh). I haven't done any research yet, but if I do get this fixed I don't mind going with a non-OEM cat if its comparable. I'm also wondering if I can get a downpipe chopped and put in there and rewelded up......not sure. Obviously, I'll also get a couple more estimates as well which is a very good idea.
Lastly, I'm a pretty frugal shopper, and I'm in the Boston area -it wouldn't suprize me if the price quoted is in the ball park as everything in the north east is more expensive, though if anyone knows of another reputable mechanic in the area who would do it for less, I'd definitely like to know!
Old 04-04-2018, 12:40 PM   #5
mmtphoto
mmtphoto's Avatar
2007 AURA XR
I have an XR with the 3.6, not an XE so I am not familar with the exhaust on your car. I too am in the NE so I can relate to how expensive it can be to find a reasonable price for any automotive service-so I have been working on my own cars for 45+ years now and rarely use anyone for anything anymore (tire mounting and balancing, the rare trans rebuilt are the only things that come to mind in the past 20-30 years). I bought a good welder, have many good high lift floor jacks, and can park a car inside and let it sit until I get it fixed since I have a lot of 'drivers', cars that are registered, inspected and insured (currently 7 vehicles). I have always been a firm believer in having more than one car so I always had a solution when I had to fix a car, even if the second vehicle is a 'beater'-although I have gotten to the point where none of my drivers are beaters anymore since I can park any one at any time and fix/improve it and still get around. They're all quite nice now, and worth parking and fixing if something comes up.
Old 04-05-2018, 06:18 AM   #6
Nigey
2007 AURA XE
Nice! Without a doubt my biggest problem is not having an indoor garage -at least in the Boston area, as well as a driveway that only supports 2 vehicles. I agree; where possible, I do all the work myself. Aside from the fact it is so much cheaper and you can use much higher quality parts than the cheapest- parts-but-charged-for-premium-prices, you at least know the quality of the job you do. That's a huge positive for me.
Sadly, I do not have the space nor the money for a beater car!
Old 04-05-2018, 09:55 PM   #7
mmtphoto
mmtphoto's Avatar
2007 AURA XR
Back in the 70's i bought new, off the showroom cars and discovered that they ended up needing work at the dealership (under warranty) anyway, or I had to get it serviced (had no garage) at wherever I could find...and I got a house in the early 80's with a tiny garage. I did repairs in it as best I could, but in 2000 I moved into a house with a FOUR CAR garage, and lots of space to park cars outside too. So I stopped buying new cars, bought interesting cars that were used but that I wanted to own, and now have many stashed all over the place. Like I said, now if I need to do something, I park it and drive something else until problems or upgrades are done. I'm (almost) 65, but really like working on my cars and I also work on friends and neighbor's cars too, so I'm always into some project or another.
Hopefully I can do this for many more years, and I hope you solve this situation-I do remember what it was like to be at the mercy of dealers, repair shops and a non-functioning car in the dead of winter with no place to fix it. Hang in there.
Old 04-06-2018, 06:04 AM   #8
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
I was told I needed a Y pipe when the flex pipes started to go. I found these, the bolt holes didn't match up exactly but a little drilling fixed that.
https://fxexhaust.com/ffr/fx2087.html
https://fxexhaust.com/ffr/fx2088.html
Old 04-07-2018, 06:56 PM   #9
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2009 AURA XR
2005 ION-3 Sedan
Looks perfect. How much did it cost?
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Old 04-10-2018, 05:37 PM   #10
imaddicted2u
2008 AURA XE
I've seen them sold for exorbitant prices on ebay but I had a local parts dealer order them in. I paid $115 Canadian for the pair. Installed them myself.
Old 04-10-2018, 09:51 PM   #11
Nigey
2007 AURA XE
Now I'm all ears.... Would you like to elaborate on what you did to make them fit, how you installed them, tools you needed, etc? I would be more than grateful!
Old 08-14-2018, 01:33 PM   #12
imaddicted2u
2008 AURA XE
Been a while. Sorry, I missed your reply. I'll answer anyway...I used a grinder and thin cutting wheel to remove the old flange bolts and to cut out the old flex pipes. Be careful not to cut them too short they need to butt together. When I test fit the new ones I found the bolt holes didn't quite line up. I used vice grips to hold the flanges together and drilled out the holes. I used a C clamp to line up the pipes and tack welded them together. I complete the welding after removing the C clamps. I used flux core wire in the welder. Getting the top of the joint towards the back welded was the hardest because there isn't much room between the pipe and the floor. I'm not much of a welder but it doesn't leak...
Old 08-14-2018, 05:45 PM   #13
dano92sl
dano92sl has a spectacular aura aboutdano92sl has a spectacular aura about
2008 AURA XR
I'm down on the Cape, but there is a chain of exhaust repair called Lou's Custom Exhaust around the Boston area and suburbs that I have had good luck with for cat replacement and other more expensive exhaust work. May vary from store to store, but worth getting a quote.
Add to dano92sl's Reputation
Rate the quality of this post and help dano92sl reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dano92sl is offline   Reply With Quote
Old 11-02-2018, 07:44 PM   #14
Nigey
2007 AURA XE
Just want to say thanks for the replies (imaddicted2u). I'm facing up to this problem soon I think as the inspection is due this month. If it passes, I'll just kick the can down the road.
Alas, I'm not an expert welder and haven't welded in over 30 years -add in the cost of buying the equipment and home done welding isn't on the cards for me. If I have to fix it, I'll post an update on costs.
dano92sl, I might be following up with that!
Old 11-06-2018, 04:48 PM   #15
imaddicted2u
2008 AURA XE
I noticed that Rockauto sells the left and right pipes with catalytic converters. Makes it a bolt in job.
https://www.rockauto.com/en/catalog/...converter,5808
Saturn Aura reliability (please sign up if you're new) mkaresh Aura General 15 10-20-2016 01:09 PM
Saturn Aura reliability - how does it compare? mkaresh Aura General 37 07-16-2013 03:47 PM
2008 Saturn Aura XE 2.4L Reliability? piratepress Aura General 9 05-27-2013 10:33 AM
Latest Saturn Aura reliability results mkaresh Aura General 30 03-04-2008 01:09 AM
Saturn Aura reliability mkaresh Aura General 76 02-10-2007 05:16 PM
