Old 03-31-2019, 08:05 AM   #1
den812
den812 is on a distinguished road
2004 VUE 3.0L
Question 3.0 L61 Engine problem ( Ignition or Fuel)
Hello there again,
have a problem with VUE 3.0 2002 L61
have an engine problem in Ignition or Fuel system
1. cold engine RUN 80% times all ok
2. hot(normal) engine RUN 100% incomplete for 2-10 attempt before RUN normal
( Video is here: http://saturnvue-club.ru/tmpp/no_run_30.mp4)
3. Cold RUN normal drive , after drive some times have errors:
system too lean bank1 and bank2 , then rundom misfire in cylinders, and Idle too higher than expected
4. when park(P) with idle engine run I have a high and high Idle RPM , but if choose drive (D) Idle back to normal. as same as make clear errors in ECU..
What do U think about ?
help me to resole this please
(screens is here:
http://saturnvue-club.ru exUSSR Saturn Owners Club org
den812 is offline   Reply With Quote
Tags
3.0, ecu, icm, l61, vue
Ignition, fuel, anything? Crow.0 S-Series Tech 1 09-16-2014 08:24 PM
Flooded Engine - Fuel Rail & Injectors Problem? zodszoo S-Series Tech 6 01-11-2013 05:36 PM
I don't have a fuel pressure gauge, is there a way to check problem fuel pump without dddaaa S-Series Tech 6 08-06-2011 03:09 PM
Ignition problem (Engine misses) radioouman L-Series Tech 8 01-19-2010 01:02 PM
Fuel/Ignition problem blue98sl2 S-Series Tech 10 07-22-2008 01:57 PM
