#1 |
![]() ![]() Join Date: Jan 2013
2001 SL2
2004 VUE 3.5L
I like a saturn wagon 1997 sw2 and want to buy but it has check engine light on and it shows two codes P0304 and p0420....
I don't have much access to car to check something major like compression test or leak down test....at the same time I dont want to buy this car if it has some major problems like piston or valve etc... How do I check whats wrong with it ? From your experience can you tell what is main reason why it will give these two codes together? Owner said he recently changed plug and wires but has not changed anything else like ignition control module or ignition coils ... If its something minor like ignition coils etc...I want to buy but not if something about head or engine ....like I said she wont allow me to check compression etc... so I have to trust on people on forum and their experience....so please advice. |
#2 |
What brand f plugs did he use? Does it idle smoothly when fully warmed up?
If the owner will not let you check it out then walk. |
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2011
2002 SL1
![]() Quote:
2015 Subaru Forester Limited "Prinny" 2000 SW2 Still Running Strong- 160K Traded In 2002 SL1 Still has Its Training Wheels on at 88K Traded In CHECK YOUR OIL! |
#4 | |
2001 SL2
2004 VUE 3.5L
![]() Quote:
Could not find out about brand of plugs... but after changing plugs no difference same rough as it was before.. |
#5 |
2002 SL1
Most likely a burned exhaust valve on Cylinder 4, And most likely needs a new Catalytic converter from it misfiring on cylinder 4 for who knows how long causing the converter to overheat and get saturated with raw gas.....
#6 | |
2001 SL2
2004 VUE 3.5L
![]() Quote:
Also is it ppssible that bad cat would cause misfire on cyl 4? Or its always misfire would cause the cat to go bad? |
#7 |
2002 SL1
Im currently working on a 05 Chevy Suburban that had a misfire for 4 months before the owner had the money to fix the bad intake gasket, now that the gasket was replaced and the engines running perfect again the converter has an issue from her driving it that long with a misfire, Usually on these computer controlled vehicals one problem will lead to another and another if not adressed right when the issue occurs, You can ask them how long its been running rough with the misfire and that will give you a good indicator of how long the converters been suffering....
#8 |
2002 SL1
^^^ This is what will cause the converter to go bad thats why in the owners manual it will state that a flashing check engine light you should shut the car off as soon as possible and have the car serviced as soon as possible, A misfire is when one or more of the cylinders are not firing correctly and burning up the air/fuel mixture correctly as a result the unburned air/fuel goes down the exhaust and the converter becomes overwhelmed and cant keep up, The longer it stays that way the worse off the converter is.
#9 |
Rough idle + P304 = burned valve on #4. listen art exhaust pipe and you will hear it, 3 good beats and a fart.
#10 |
2001 SL2
2004 VUE 3.5L
#11 |
![]() Join Date: Sep 2015
How can i fix this Burnt valve myself.....I have sw2 1996, 186000 miles, a bunch of carbon build up from clogged egr still ran it about 1 year. Need to fix now.
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2013
What is your skill/experience level? The cylinder head has to come off for valve-work or replacement. How much money and effort are you willing to spend? As a wholly DIY project it can be in the $100-200 range to just replace one valve. About 15 hrs. of work to R&R the head, depending on how fast you can work and how good a job you try to do...
Bookmarks |
Tags |
compression, p0304, p0420 |
2000 Saturn SL1 Codes P1599, P0420, P0422 | ScottMac | S-Series Tech | 15 | 08-12-2013 01:57 PM |
Codes U2105, P1780 & P0304 2000 LW2 | rigo009 | L-Series Tech | 3 | 02-26-2012 04:50 AM |
codes po171,p0304,p0446 what could it all mean | chevotass | Ion Tech | 5 | 03-28-2009 11:28 PM |
Trouble Code P0304 & P0420 | thaiwebb | S-Series Tech | 0 | 07-07-2008 10:11 AM |
P0304, P0341, P0410 codes all at once | nitsua y zarc | S-Series Tech | 2 | 03-17-2008 07:23 PM |
