Old 07-19-2012, 01:04 PM   #1
l300eri
l300eri is on a distinguished road
Default 2002 L300, P0304 help please!!
Hello there, I have a 2002 L300, 3.0 ltr. The service engine light came on, it is code P0304, cylinder 4 misfire. I replaced the spark plug in 4, nothing, new coil, nothing, switched the #4 #2 fuel injector, nothing, checked compression on #4 it was 195 or so. I am at a loss of what this may be. Please anyones help or suggestions would be greatly appreciated!!!! Thanks in advance!!
l300eri is offline   Reply With Quote
Old 07-19-2012, 06:10 PM   #2
bluesl2
bluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of lightbluesl2 is a glorious beacon of light
bluesl2's Avatar
Default Re: 2002 L300, P0304 help please!!
Check and make sure you have injector pulse on #4. Are you sure you are getting spark to that cylinder? Only other thing I can think of is maybe the boot between the coil and plug may be damaged.
Old 07-19-2012, 09:44 PM   #3
l300eri
Thanks for the input! After all this messing around, I found that the spark plug I originally bought was the wrong on!!! Thanks A AUTO!!! lol. New spark plug fixed the problem, thanks for the input!
Tags
coil, fuel injector, misfire cylinder 4, p0304, sparkplug
04 L300 P0304 Code trouble nheven L-Series Tech 3 09-25-2011 02:25 AM
P0304 and P0507 Codes On 2002 SL1 = Leaking Intake Manifold Gasket at #1 Cylinder motoboymatt S-Series Tech 4 04-24-2010 06:28 PM
2002 l300 justin3 L-Series Tech 3 04-08-2007 10:20 PM
2002 L300 bearwolf46 L-Series General 1 02-08-2006 11:26 AM
Fs: 2002 L300 Urbanrover Classifieds 0 03-15-2005 11:55 AM
