Old 02-04-2010, 02:07 AM   #1
bobyjones
bobyjones is on a distinguished road
Default Saturn wire set, need to find comparable
read that Msg coils and a Taylor wire set are optimal for best MPG, anyone know of a comparable wire to Taylor for Sl2's? I don't think they make them for saturns, but msg makes the coils...
can anyone help?
bobyjones is offline   Reply With Quote
Old 02-04-2010, 02:49 AM   #2
Default Re: Saturn wire set, need to find comparable
Stay with stock coils or you will be very sorry and out about 100.00. As for wires Magnecor makes a 7mm direct fit wire set that functions just fine and should last for a good while. http://www.magnecor.com/magnecor1/main.htm Get the part number for the set you want and then do a search for a discount. The 7mm set is a 60 or so list and it can be found for 40 or so if you look.
Old 02-04-2010, 02:57 AM   #3
bobyjones
are magnecore the best set for saturns? maybe for efficiency?
also why no on the coils? will it blow my car up? just curious
Old 02-04-2010, 05:26 AM   #4
Pitcher
Pitcher's Avatar
I just picked up a set of Belden Max from NAPA. $20. Made in the USA.
Owned 4 other S-Series.
Old 02-04-2010, 08:33 AM   #5
92SL1Mann
92SL1Mann is on a distinguished road
1992 SL1
1996 SC2
Stick with OEM coils as some aftermarket ones had issues, plus the output is identical. Why pay $100+ for a red or yellow outer casing?
1992 SL1, 376,000Kms
1996 SC2, 243,000Kms
92SL1Mann is offline   Reply With Quote
Old 02-04-2010, 11:04 AM   #6
The Magnecor wires will outlast a big handful of standard carbon-kevlar wires. The carbon-kevlar wires will last about 2 sets of plugs and then they are not functioning at peak efficiency.
Pulled plug wire only to find coil is wasted! aaron7 S-Series General 2 07-11-2009 06:12 PM
Saturn alternators: 1-wire, 2-wire, 3-wire? JohnHupp S-Series Tech 5 11-25-2008 08:10 PM
How to find 12V keyed wire under dash - '04 Vue MikeF Vue Tech 6 08-10-2007 09:02 PM
Help, Trying to find the correct VSS wire in a 97 Saturn SC2 DOHC Automatica Trans. MacTech84 S-Series Tech 1 07-20-2007 11:18 PM
Where to find NGK's on the web/ Wire Question JLWhid S-Series General 4 09-18-2005 09:45 PM
