Old 12-26-2008, 01:15 PM   #1
rockermikey
rockermikey is on a distinguished road
1999 SL1
Wrench Oil Light Flickers While Idling
My oil pressure light flickers when the car is idling at a stop light while in gear and sometimes even when in park. It is a 1999 SL1 with 183 000 kms on it....could it be my oil pump is going and is it ok to drive? Any info will be greatly appreciated....thanks.
Mac
rockermikey is offline   Reply With Quote
Old 12-26-2008, 01:33 PM   #2
2NDSOUT
2NDSOUT's Avatar
1999 SL
Default Re: Oil Light Flickers While Idling
When was the last time you had the oil changed?
You are low on oil, otherwise this light wouldn't flicker. I would check your oil level, and if it is low you need to top it off.
Your car may be starting to show signs of oil burning too.
Just my thoughts.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Old 12-26-2008, 01:37 PM   #3
rockermikey
1999 SL1
The oil level is perfect and was changed about 3000 kms ago.....btw...I love the Genesis album Seconds Out .....lol...one of my faves...
Mac
Old 12-26-2008, 01:51 PM   #4
The pressure switch could be working on failing also. I think I would try a new switch.
What brand and weight oil are you using? They are not all the same.
Old 12-26-2008, 03:09 PM   #5
rockermikey
1999 SL1
I am using Castrol 5W-30....
Old 12-26-2008, 08:08 PM   #6
Well, Its not known for going thin. But, you could try a synthetic blend as its called on the package. And just about any filter other than FRAM. If that does not solve it then, a new pressure switch.
Old 12-26-2008, 08:31 PM   #7
Ritz
Ritz's Avatar
As others have said, it might just be the oil pressure switch. They are cheap and easy to change. If that doesn't solve your problem, you need an oil pump.
Cheers,
Old 12-26-2008, 08:31 PM   #8
jts749
jts749 is on a distinguished road
jts749's Avatar
oil pump could be worn out, or you might have a worn out bearing
jts749 is offline   Reply With Quote
Old 12-26-2008, 10:10 PM   #9
Canyon
Canyon has a spectacular aura aboutCanyon has a spectacular aura about
1999 SL1
Do you hear the valves clatter when the light comes on? That would indicate low oil pressure.
The easy thing to try is to replace the oil pressure switch as suggested by others. Check the connection to the oil pressure switch first, it might be corroded.
To test if the oil pump is going you need to hook up an oil pressure gauge. This is easily done while you have the oil pressure switch out as it gives you a convenient place to hook in to. Harbor Freight sells an inexpensive oil pressure tester. Got one and it works just fine.
Canyon is offline   Reply With Quote
Old 12-27-2008, 01:07 AM   #10
rockermikey
1999 SL1
Yes..the valves clatter at first when you start the car and the oil light is on then they get quiet once the oil reaches the valves....I bought a new sensor but can't get the old one off.....Lordco told me I need a special socket to remove it.....I will pick one up and get under the car once the snow has melted...thanks for the info...
Cheers
mac
Old 12-27-2008, 03:56 PM   #11
Canyon
1999 SL1
How long have you been hearing the valves clatter and the oil light on when you start the car? The oil pressure should pop right up after starting. I don't hear the valves clatter on any of my cars. The only lights I see on my cars are when they are tested when initially starting the car. Nothing beyond that.
You may have a bad oil filter. It couldn't hurt to change the oil and filter just to rule them out. What brand of oil filter are you using?
Old 12-27-2008, 09:10 PM   #12
rockermikey
1999 SL1
Wrench Re: Oil Light Flickers While Idling
I believe it is a Fram filter...judging by a couple of posts here Fram is a no-no....
Mac
Old 12-28-2008, 01:52 AM   #13
Canyon
1999 SL1
Do a search as there has been much discussion on filters on the forum. Fram filters fall toward the bottom. A bad oil filter can ruin your whole day along with your engine
Old 12-28-2008, 08:33 PM   #14
Scott Peterson
Scott Peterson is on a distinguished road
Scott Peterson's Avatar
Originally Posted by canyon View Post
do a search as there has been much discussion on filters on the forum. Fram filters fall toward the bottom. A bad oil filter can ruin your whole day along with your engine :d
fram = garbage
1997 sl2, auto
I love the greaters too...you can't even tell who the *** he is greating. Both of his eyes are looking different directions. You only go to walmart for comic relief.
Scott Peterson is offline   Reply With Quote
Does your oil light display when your saturn is low in oil? AtlanticBeach S-Series Tech 32 05-21-2009 05:54 PM
1995 saturn coolant light flickers idles up and down and hesitates reed88 S-Series General 33 08-27-2008 10:20 PM
My oil light. (Rated R, includes oil related discussion) burnout Vue General 22 06-29-2006 12:53 AM
Idling at traffic light ciw S-Series General 4 03-23-2005 10:29 PM
Engine coolant light flickers rrharmon S-Series General 3 02-11-2004 01:09 PM
