Old 04-28-2005, 12:36 PM   #1
dtm1962
dtm1962 is on a distinguished road
dtm1962's Avatar
2004 VUE 3.5L
2005 ION-2 Sedan
Default Solution Found:!!!! for Passenger Side Windshield Wind Noise/Rattle
I 've had a noise comimg from the windshield ares on the passenger side since I bought my 2005 Ion 2 Sedan.
The noise would only seem to happen when I had a fairly strong crosswind going from the driver's side towards the passenger side during my travels.
I intially brought it in and the Tech adjusted the trim piece (that you can have color co-ordinated that run from windshield back to rear window - I forget what you call it) but to no avail.
I would travel to the dealer (going east) and the noise would have disappeared before I can let the Tech go for a ride. SO when I return home going West the Noise would reappear!
So I investigated and discovered that the metal bracket that secures the ANTENNA to the body will make contact with the Plastic body piece ONLY when you flex the antenna and let it vibrate back and forth from Drivers Side to Passengers Side as a CROSSWIND would do and that ANNOYING sound results.
If you flex the antenna and let go in a front & rear direction - NO CONTACT and No annoying rattle!!
Check it out for yourself. Maybe my antenna mounting is a little Off-center or my plastic body panels are misaligned , OR it is a DESIGN Defect.
Let me know what you guys found!
Add to dtm1962's Reputation
Rate the quality of this post and help dtm1962 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dtm1962 is offline
Old 04-30-2005, 11:47 AM   #2
dtm1962
dtm1962's Avatar
2004 VUE 3.5L
2005 ION-2 Sedan
Default Re: Solution Found:!!!! for Passenger Side Windshield Wind Noise/Rattle
UPDATE:
In order to stop the rattle I stuff a piece of 1/4" square by 4" weatherstipping foam around the base of the antenna and it eliminates the base making contact with body panels. It limits its travel and isolates the base & panels and minimizes the rattle.
FYI : The antenna & base is only secured to the plastic vetical part of fender via a two hole half clamp similar to a electrical conduit or copper pipe support. This allows much more "sloppy" movement then the conventional method of securing thru the top of the metal fenders like other cars.
Has anyone else experience this noise/rattle????
dtm1962 is offline
Old 10-03-2005, 11:56 AM   #3
saturn_69
saturn_69 will become famous soon enough
saturn_69's Avatar
Yes, but I didn't know what it was coming from. It sounds more towards the front of the car on mine. I'll have to try it. Thanks.
"That government is best which governs not at all; and when men are prepared for it, that will be the kind of government which they will have" - H.D. Thoreau
Add to saturn_69's Reputation
Rate the quality of this post and help saturn_69 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn_69 is offline
Old 10-04-2005, 07:38 AM   #4
mr weather
mr weather is on a distinguished road
Wow, I've experienced the same sound, particularly in a strong head/crosswind. I'll have to check the antenna mount to see.
Thanks for the tip!
Add to mr weather's Reputation
Rate the quality of this post and help mr weather reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mr weather is offline
Windshield and wind noise Chetpk Vue General 6 12-11-2008 11:35 PM
Passenger side rattle when cold john95SW2 Vue Tech 2 01-03-2008 05:49 PM
Front suspension noise/rattle over bumps passenger side Cessna S-Series Tech 1 11-21-2007 03:14 PM
Windshield - replaced 2x front corner near windshield passenger side base of A-Pillar mrbios S-Series Tech 6 02-12-2007 04:13 PM
Windshield rattle/vibration/wind noise on '06 Vue missi blue Vue General 3 12-09-2006 06:14 PM
