Old 11-17-2012, 06:14 PM   #2041
Spaz
Spaz will become famous soon enoughSpaz will become famous soon enough
Spaz's Avatar
Default Re: What did you do to your S-Series today...
Originally Posted by adventureoflink View Post
Awwww, and I thought I was being original or otherwise unique too
ah, cool... what I would've done was got a 3-in-1 outlet pod and triggered it off a relay, as well as re-wire the stock adaptor but hey to each his own.. you also managed to take the yellow lead off your aftermarket radio and put it on its own line, right?
I'm only running a Sony head unit rated at 200 watts maximum, no external amplifier. I very rarely play the music loud so I figure it'll be OK. I'm open to feedback and suggestions if this setup will still overload the F-5 circuit.
Add to Spaz's Reputation
Rate the quality of this post and help Spaz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Spaz is offline   Reply With Quote
Old 11-17-2012, 08:10 PM   #2042
guy_450
guy_450 will become famous soon enough
guy_450's Avatar
2001 SW2
Son sold his 2002 SL1 4AT today
next step:
Son to buy my 2002 SL2 4AT
Winter is almost here, so the time has come to put back ice tires on the SL2 as well buy brand new Ultra-Low Rolling Resistance Nokian Hakkapeliitta+R, steel rims & TPMS ($$$$ ouch !!) for the Volt. Next week end will be the SW2 turn.
2000 SW2 5MT silver (sold, at my regrets)
2001 SW2 4AT silver (garaged)
2013 VOLT instant torque & regen braking from electric motor go so well together !!
Add to guy_450's Reputation
Rate the quality of this post and help guy_450 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
guy_450 is offline   Reply With Quote
Old 11-19-2012, 09:03 AM   #2043
dbetz
dbetz will become famous soon enoughdbetz will become famous soon enough
1999 SW2
2000 SL
Busy weekend for me:
On the 2000 SL - Replaced TPS (High idle issue); Cleaned Throttle body; Replaced ECTS and thermostat; flush and fill coolant - hose flush and ran with cleaner, distilled water rinse, fresh coolant and distilled (first for me); new top motor mount; new trans mount; new wipers; and washed the dirt road off.
On the 1999 SW - New wipers all around and new arms on the front that aren't rusty.
Oil changes are coming up, still need new wires for the SL, and it looks like the front brake pads and rotors are coming due on the SL.
Thanks! David
1999 SW2 Auto 150k miles; Dark Plum Metallic
2000 SL 5-Speed 214k miles; Silver
Add to dbetz's Reputation
Rate the quality of this post and help dbetz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbetz is offline   Reply With Quote
Old 11-19-2012, 11:50 AM   #2044
Madness10
Madness10 will become famous soon enough
Madness10's Avatar
Busy day for me also. Replacing the front hubs and bearings(both sides),putting new front sping cushons on and reindexing them the correct way(sqeaking), new calipers,rotors and brake pads. Getiing my code scanner in today, so I'm going to read the live data to find out what the temp on the car is.
Add to Madness10's Reputation
Rate the quality of this post and help Madness10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Madness10 is offline   Reply With Quote
Old 11-19-2012, 01:02 PM   #2045
Originally Posted by Spaz View Post
Rewired the 12 volt socket in the trunk directly to the UHJB and added twin auxilliary 12 volt sockets wired directly to the UHJB to take the load off of the infamous F-5 connector.
Was going to comment on how clean and rust-free everything is, then looked at your location No road salt/snow
Yesterday, loosened the lower radiator hose (again), tried to get the hose on better, and retightened. Had a slow leak under pressure there after the radiator replacement, thought I had it licked once but started leaking again. On the plus side, maybe a mouse will drink it and die
Old 11-19-2012, 03:19 PM   #2046
proveniebam
proveniebam is a jewel in the roughproveniebam is a jewel in the roughproveniebam is a jewel in the rough
Installed a new coolant resevoir.
Blasted low coolant lights kept coming on. Sensor inside wasn't working.
Go to junkyard and pull off a resevoir. That one didn't work.
When taking a second resevoir some prat shreeded the nut. Ended up having to shear off the head using a 4in wrench. Damn idiots.
Still for $4.54 instead of $45 new it was worth the damaged knuckles.
Add to proveniebam's Reputation
Rate the quality of this post and help proveniebam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
proveniebam is offline   Reply With Quote
Old 11-19-2012, 08:39 PM   #2047
Spaz
Spaz's Avatar
Yup, not much snow where I'm at. I live approximately one mile from the beach. If I spot any oxidation starting, I nip it in the bud before it gets worse. The engine cradle, door sills are rust free. I haven't had to wrestle with any frozen nuts or bolts when I worked on the car. When I changed the LCAs, the bolt at the cradle connection came out very easily.
Old 11-20-2012, 01:58 PM   #2048
proveniebam
Attached new front bumper to SC2. No more duct tape for me.
Old 11-20-2012, 05:35 PM   #2049
<-- BTDT
OK, now you're just braggin'
My wife kinda wants to live on the islands when I retire, but she's fair-skinned and prone to sunburns/skin cancer. But where ever we decide... snow won't be part of the equation
checked the lower radiator hose... think I got the small leak stopped.
Old 11-20-2012, 06:41 PM   #2050
CheapRacer
CheapRacer is on a distinguished road
CheapRacer's Avatar
1996 SC1
1996 SC1
Took both of mine for their weekly drive up the road and back(4-5 kms). Sportsman class car got a simulated 1/4 mile pass and some hard braking and the other one was just driven normally. Both of them are back in the garage now and our newest one will not see the light of day again until it's sitting on the Super/Gas chassis. If I'm carefull during the stripping process we'll have a ton of spare parts for the Sportsman class car.
Add to CheapRacer's Reputation
Rate the quality of this post and help CheapRacer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CheapRacer is offline   Reply With Quote
Old 11-24-2012, 07:03 PM   #2051
proveniebam
Relieved frustration by taking a hammer to the left rear quarter panel.
Pigs ear to take off specially when one of the main bolts is under the trunk lid and the lid is welded shut.
Then front end of the quarter panel the rivets can only be accessed if the door is open. But it too is welded shut.
In the end got the panel off but I think there's going to be a lot of riveting going on to re-install the new panel.
Old 11-25-2012, 06:18 PM   #2052
brags
brags will become famous soon enoughbrags will become famous soon enough
1996 SL1
sprayed the underneath using Krown rustproofing makes me
ready for old man winter.
" Any man that doesen"t share his knowledge in cars is wrong to do !"
Add to brags's Reputation
Rate the quality of this post and help brags reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brags is offline   Reply With Quote
Old 11-25-2012, 07:03 PM   #2053
guy_450
guy_450's Avatar
2001 SW2
Put winter tires on my 2000 SW2 and spray some rust proofing too but it was Fluid Film
Old 11-25-2012, 07:31 PM   #2054
brags
1996 SL1
nice Saty" Fluid film will work fine guy450
i used the Krown stuff underneath and was quite impressed at how "easy
it sprayed on" i managed nice even coates very little dripping to say the least.
also used it in and around a few places by around the engine bay.
Old 11-26-2012, 08:00 AM   #2055
bumpdraft
bumpdraft's Avatar
1998 SW2
Acting on my paranoia, I bought bright LEDs for the
High Stop Light and Stop/Running Lights for my SC2
and
High Stop Light for my dad's SW2
Thanks to Madness10 for pointing out superbrightleds DOT com
I went with their "recomended" bulbs. Hope they are not too bright and cause rage in dim drivers.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 11-26-2012, 10:38 AM   #2056
proveniebam
Installed new left rear quarter panel.
Old 11-26-2012, 11:24 AM   #2057
SLCraig
Fluid Film is great stuff.
I use either that or Krown T40.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-26-2012, 07:45 PM   #2058
Pitcher
Pitcher's Avatar
and
Hummm... I may have to get those!
Owned 4 other S-Series.
Add to Pitcher's Reputation
Rate the quality of this post and help Pitcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-26-2012, 09:29 PM   #2059
Spaz
Spaz's Avatar
Did it go on easier than it came off?
Old 11-26-2012, 10:06 PM   #2060
bumpdraft
bumpdraft's Avatar
1998 SW2
If you can wait a while, I can let you know if they are too bright. (Think exiting some big event where you're constantly blinding the driver behind you....if you care about those things)
The last trip I took, I had a pickup hit the brakes at the last second. He had my full attention. Getting hit when you're 200 miles from home can be a hassle.
Everybody keep in mind I have a gray car. Not the brightest color for visibility. Brighter lights might break the other driver's trance (If I can't figure out how to mount a flare launcher, that is)
I remember being in a company van on the expressway. The guy driving fumbled for the 4-way flasher button when traffic did a sudden brake check and stop.
I thought, "what a pansey"
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 04:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 08:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 02:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 08:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 09:03 PM
