Old 11-21-2005, 04:02 PM   #1
mcfly
mcfly is on a distinguished road
Default 99 SL High Idle, Miss on Cylinder #1, & Vacuum
This is my first post. I have read many of the threads but wanted to post my specific problem.
My SES light has been on for a while. Read the codes and they show high idle, miss on cylinder #1, and vacuum. We did the following:
-New spark plugs & wires - spark plugs were worn, cylinder #1 was discolored, no oil was present
-Spark is present and seems to be good
-Checked compression on cylinder one (seemed OK)
-Checked IAC, removed and cleaned (seemed ok)
-Sprayed around intake manifold gasket and didn't see a leak
-Filled up with high grade gas at Citgo
-Added fuel injector cleaner to tank
I drove the car 100 miles and the SES was still on and the engine is still idling high. I removed the battery wire to reset the system. I am planning to drive the car today and tomorrow to see if the light comes back on.
Any suggestions?
Thanks again.
Add to mcfly's Reputation
Rate the quality of this post and help mcfly reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mcfly is offline   Reply With Quote
Old 11-21-2005, 04:59 PM   #2
hugh
hugh will become famous soon enough
Default Re: 99 SL High Idle, Miss on Cylinder #1, & Vacuum
Welcome to Saturnfans.
You will get better attention by posting to the S Series forum........that's where all the knowledgeable S owners hang out.
Add to hugh's Reputation
Rate the quality of this post and help hugh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hugh is offline   Reply With Quote
Narrowed down my high idle to Vacuum leak fourty6an2 S-Series Tech 4 04-07-2009 09:55 PM
Missfire & High Idle Blues - What Did I Miss? gtare S-Series Tech 10 03-31-2006 11:00 PM
99 SL High Idle, Miss Cylinder #1, Vacuum mcfly S-Series General 6 11-26-2005 12:54 PM
3 Door coupe, Miss on #1 cylinder, High Idle greenrockguard S-Series Tech 20 02-18-2005 05:00 PM
vacuum leaks, high idle Jeff P Miscellaneous Tech 4 04-25-2002 03:24 PM
