Old 12-13-2019, 05:25 PM   #1
mkez1
mkez1 is on a distinguished road
Default V6 Rattling noise - gone when warm
I have a high mileage 2006 Vue V6 that has an engine rattle as you increase revs. It clears once the engine is warm and the car runs fine. I'm wondering if it's something to do with lifters but I don't see a lot of online posts reporting similar issues with the Honda v6. Anyone come across this before?
Add to mkez1's Reputation
Rate the quality of this post and help mkez1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mkez1 is offline   Reply With Quote
Old 12-28-2019, 02:57 PM   #2
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
Default Re: V6 Rattling noise - gone when warm
The 3.5 liter V-6 Engine dose not have Hydraulic lifters. It has solid lifters and if one or more were loose they would make noise all of the time and would not change with engine temperature change. Solid lifter engines typically have a light ticking noise at idle. if your VUE has a growl or a vibration noise that changes when shifted to drive or reverse you should take a look at the engine front mount that is in front of the right side strut tower underneath the air filter box.
Add to bern's Reputation
Old 12-28-2019, 09:04 PM   #3
Vue6
Vue6's Avatar
2006 VUE Red Line
...Sounds like the heat shields possibly. look underneath, when cold ,see if the shields move or are rotted away, take some steel wool and cram some in between the shield and cat. It should take of the rattle, it did in mine, just my.02, DC.
Add to Vue6's Reputation
Old 01-02-2020, 09:36 PM   #4
JosephN79
JosephN79 is on a distinguished road
JosephN79's Avatar
2004 VUE Red Line
I had the same problem when I got mine in 2012. I have a 2004. Sometimes Id get a bad rattle when starting engine and Id hear it until engine warmed. Eventually I changed the engine mount under the air box on pass side. The bushing inside was deteriorated, but I think as it warmed up and rubber expanded some it helped insulate from the frame. Anyway. I replaced it and noise was gone. You wont believe all the things I thought it was, and how simple it ended up being. 😁
Add to JosephN79's Reputation
Rate the quality of this post and help JosephN79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JosephN79 is offline   Reply With Quote
Old 01-03-2020, 05:33 PM   #5
jco35
jco35 is on a distinguished road
2005 VUE Red Line
Same thing happened to me at about 80K. Mount was completely shot.
Add to jco35's Reputation
Rate the quality of this post and help jco35 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jco35 is offline   Reply With Quote
Old 01-05-2020, 01:52 AM   #6
JosephN79
JosephN79's Avatar
2004 VUE Red Line
Jco... I bought mine with 77k miles. I was 80-85k when I finally changed mine, the rubber was shot as well. Made a huge difference when replaced.
Old 01-11-2020, 07:50 PM   #7
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2005 ION-3 Sedan
what a coincidence, i'm experiencing this in my Vue.
2007 with 80k miles (florida car).
how big of a job is that motor mount replacement?
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Old 01-14-2020, 05:08 PM   #8
jco35
2005 VUE Red Line
Not that big of a job. Just make sure to support the engine with a jack before taking the mount off.
Old 01-15-2020, 04:41 PM   #9
SL2 Ride
2005 ION-3 Sedan
is there a good bracing point that's easy to use?
I'd hate to have to just put the jack under the oil pan...
Old 01-17-2020, 11:53 AM   #10
JosephN79
JosephN79's Avatar
2004 VUE Red Line
I put a 2x6 piece on the jack and oushed up on the oil pan. It doesnt take much pressure at all. You just need to relieve the weight off the mount. The mount on top of the engine is really easy.
Old 01-23-2020, 07:07 PM   #11
Bismarck318
Location: Birthplace of Rust, FKA The Heart of the Rustbelt, AKA The Angry White Planet Ohth
I had a shaking @ highway speeds, had to have some mount bushing replaced to the tune of $550, did not solve the shaking totally, but greatly improved it.
Sounds like the same thing you described, different symptom.
Add to Bismarck318's Reputation
Rate the quality of this post and help Bismarck318 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-31-2020, 07:21 PM   #12
jco35
2005 VUE Red Line
Have you checked your front engine mount?
AC rattling noise liarliar17 S-Series Tech 7 03-11-2014 05:11 PM
AC Rattling Noise mirandm L-Series Tech 1 06-30-2008 12:26 PM
Rattling noise is still there Son93SL2 Miscellaneous Tech 6 08-15-2002 08:44 PM
Rattling Noise Tanya97SC2 S-Series Tech 8 08-13-2002 10:03 PM
rattling noise sc295 S-Series Tech 5 12-10-2000 04:11 PM
