Old 11-22-2019, 10:04 PM   #1
Core-Lokt
Core-Lokt is on a distinguished road
Default Door Lock Questions
I recently bought an '05 Vue Base and I have some issues with the door locks. I got one key with the vehicle. I needed to have the windshield replaced, so a mobile service was to do it. However, when they came by, they said the doors were locked (I *thought* I left them unlocked). Since the only key was left inside in the event the windshield tech needed it, I had to get a locksmith out. While he was there, I had another key made.
The locksmith tries to stick the key in the door lock, and it won't go. He thinks he made an error and makes another key. He tries it in the ignition, and it works. Puzzled, he tries my original key and says it won't go into the door lock, either. He then asks me if I have the fob, and I tell him there is none. He felt strongly there ought to be one, and suggested I get one online, as they're inexpensive and easy to program. He also said it's possible the ignition switch was replaced, and the key won't work on the doors.
Meanwhile, there is a lock/unlock rocker switch near the power window switches. Pressing it does nothing, either way. The clutch was replaced before I bought it, and it's possible that switch is either broken or disconnected when the shifter was presumably removed. I'll look into that, this weekend. I know the power window switch was disconnected, as it was inoperable, and the cubbyhole by the shifter was not put back. That plug was visible, though.
Lastly, there is a circular space where a key lock seems like it ought to be on the liftgate, but no slot. Perhaps there is no provision for manually unlocking the liftgate with a key?
In short, what I'd like to know is:
1) Did base-model Vues come with a keyless fob standard or in an optional package? I got a pair, as they weren't costly.
2) If so, does anyone definitively know how to program one? Searching online, I see A: It must be done at a dealer or locksmith B: Use a jumper wire on two ports method C: Press door unlock switch and initiate programming sequence described online.
3) If that (I guess) master lock switch by the power window switches is disconnected or defective, could it prevent inserting a key in the exterior door lock? Or is the locksmith's guess on the ignition might've been replaced more likely? Perhaps something to do with the interior electric lock switch on the doors?
4) Is there no external lock for the liftback? If not, I guess where the keyhole should be was deliberately blocked off in the liftgate latch handle. Or is that switch by the shifter close to the power window switches for the liftgate?
Thanks in advance for any help. There's no owner's manual (of course), and online information is short.
Add to Core-Lokt's Reputation
Rate the quality of this post and help Core-Lokt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Core-Lokt is offline   Reply With Quote
Old 11-22-2019, 10:57 PM   #2
focusofheart
focusofheart is a jewel in the roughfocusofheart is a jewel in the roughfocusofheart is a jewel in the rough
Default Re: Door Lock Questions
Originally Posted by Core-Lokt View Post
...There's no owner's manual (of course), and online information is short.
You will find an owner's manual at this website.
https://justgivemethedamnmanual.com/...owners-manual/
Scroll down the page and you will find the pdf download (3MB) link. You can also look at the manual online to see if it is what you want.
Saturn 1998 - SL2 automatic
Singer 1952 - 301A knee driven
Add to focusofheart's Reputation
Rate the quality of this post and help focusofheart reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-23-2019, 07:32 AM   #3
Core-Lokt
With the help of the manual, I now know the partial answer to question 3; that switch has nothing to do with the door locks. That is a rear door window lock-out switch.
It seems that Vues should have keyless fobs, also. Apparently, that is how to unlock the liftgate if the doors aren't locked. So questions 1 and 4 are solved.
All I'm left with is to figure out is about why I can't insert a key into the external door locks. IDK if it's to do with programmable locking, the Theft Deterrent System , or the possibility that the ignition lock was changed. I've seen plenty of times where a key wouldn't work, but never where a key wouldn't at least partially enter a lock cylinder.
Only thing left to definitively solve is the fob programming procedure. I'll look again on YouTube, but if anyone knows if it's either the jumper wire method or pressing the door lock switch to initiate the process, please post here. Again, thanks for any help.
Old 11-23-2019, 01:06 PM   #4
focusofheart
please read this thread - Re: Programming Keyless Entry 2005 VUE?
http://www.saturnfans.com/forums/sho...d.php?t=197411
online information
https://blog.keylessentryremotefob.c...ob-remote.html
"...There is no onboard programming procedure for this vehicle. This vehicle requires special equipment be connected to the vehicle to program the keyless remote. Try a locksmith before the dealership, they are usually 50% the cost...."
Old 11-23-2019, 07:31 PM   #5
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2005 ION-3 Sedan
for what it's worth, I got an acdelco for mine, and it works flawlessly. but that being said, you can get generic replacements on ebay for a lot less.
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Old 12-22-2019, 02:58 PM   #6
As focusofheart stated in post#4, the link addresses who can program remotes - GM or locksmith. Vues cannot be programmed at home, period. Both must have GMs Tech II scantool, not an ordinary reader or scantool sold everywhere. An alternative some here have found is VCX Nano, a foreign clone at reasonable cost for more than decoding generic error codes. It decodes abs, tcm, illuminates the instrument panel, and programs remotes. Online remotes are less costly than GM and works fine. I bought a pair for around $28 including shipping and programmed them at home with VCX Nano. I bought VCX Nano to track a recurring cel related to seasonal xmission shifting issues. My generic reader cannot decode GM specific errors. VCX Nano also has the capability to go online to connect to GMs TIS web for more connectivity but a subscription fee is required to have access to GMs technical support website for scantools.
In general, all Saturns made since model year 2000 have GMs factory Passlock security with one yellow indicator of a car with a large padlock. Some models near the end of Saturn changed over to rfid/chipped keys. Your key is plain without rfid. Security is displayed in one of four modes; off, blinking once every few seconds, flashing quickly and on. On means Passlock failed internal self tests and disabled itself from interfering with engine running. When security flashes, Passlock disables injector operation - the starter can crank the engine but without injectors operating, the engine will never fire up.
If security isn't flashing or on permanently, this problem may be related to main power or starter. Main power; battery, battery cables, their connections. A quick way to test any starter on a vehicle requires either a remote start switch and lengths of wire with alligator clips to remotely power the starter or crawling under and using a screwdriver/needle nose pliers to short two starter terminals - the large terminal with battery cable connection and the small terminal with a single wire, usually labeled in wiring diagrams as the S-terminal. Shorting these two starter terminals bypasses the starting circuit to power the starter immediately if battery and battery cables are in good condition. This test can determine between a power or starter issue.
When a key can be removed from the ignition switch after turning ignition on, the key is worn. Ignition keys should never be removable with ignition on. Have GM make new keys based on VIN info. This can answer whether or not the ignition switch was replaced or not. Most likely not. With almost everyone using remotes, door lock cylinders are more likely in new condition and may resist a worn out key. In one sense, most ignition and door locks still use basic brass tumblers in pot metal housings. Trouble free and works for millions of vehicles around the world.
Old 12-24-2019, 08:51 PM   #7
Core-Lokt
Thank you @fdryer. After the new year, I will go to the closest GM dealer and get a new key. After I get that (and hopefully starting), I'll have the fobs programmed.
Old 12-28-2019, 06:25 PM   #8
Core-Lokt
I had a new key made today, and it almost works the doors, but doesn't even turn in the ignition. If I've posted the link correctly or have the privilege, one can clearly see the difference in key profiles. It's possible the Chevrolet dealer tech didn't make quite a correct key where the doors will manually unlock, but it was just $10.00. Seems fairly clear the ignition has been changed at some point. IDK what I'd do to get the tumbler sequence for another ignition cylinder.
Haven't tried to jump across the solenoid, as it's been wet. EDIT: I don't have link-posting privileges until 15 posts made. No matter, as the new and old keys are notably different.
Old 12-28-2019, 09:51 PM   #9
To my knowledge, door and ignition lock cylinders are matched so only one key is needed. GM can configure replacement door or ignition lock cylinders. Licensed locksmiths can do the same. Using a new VIN based ignition key and either GM or locksmith can recode the ignition lock cylinder. A skilled, educated diyer can probably do the same with service manual info and tools.
Old 01-04-2020, 06:34 PM   #10
Core-Lokt
I got some WD-40 and sprayed inside the door locks. With a couple of in-out cycles, the key the Chevrolet dealership made went in all the way and functions fine. So, that's OK.
For S&Gs, I tried the new key on the ignition. Again, it didn't go in far (as described earlier, the profiles are noticeably different). However, there was some resistance in removing it. So I tried the old key, and it started. I can't help but think the cylinder is worn to the point of causing intermittent starting problem-and it likely was from when I accidentally found I could remove the key while running.
When time allows, I'll go to the Chevrolet dealer and have them install a new cylinder with the original key code, and program the remotes. Then, I should be done with the lock issues. Thanks again, all.
Where to buy door lock housing, or door lock kit for 2002 Saturn SL? clinteastwood S-Series Tech 7 04-20-2018 02:27 PM
Manual door lock will lock but when I close the door it will unlock. mmarquez S-Series Tech 4 04-08-2015 08:26 PM
Newbie door lock questions gegray Vue Tech 4 12-17-2008 10:44 AM
2006 Strn Vue wiper fluid, Viper starter/alarm, & door lock questions GwenRoka Vue General 1 11-20-2008 07:49 PM
Door lock - key and remote questions CA-Legal-Vette Vue General 10 04-16-2008 01:51 PM
