Old 06-30-2020, 09:58 PM   #1
rgrafton
rgrafton is on a distinguished road
rgrafton's Avatar
2002 SC1
Default Changing power steering fluid
Attempted to replace power steering fluid using turkey baster method... I was only able to get 8oz out of the reservoir even starting the car and turning the wheel all the way to the left and checking the reservoir again and turning the wheel all the way to the right. Topped it off with 8oz of fresh Valvoline fully synthetic ATF (ATF+4).
Any idea why I couldn’t get more out?
2002 SC1 5 speed 140k miles
1994 SL 5 speed 150k miles on engine (250k+ miles on car, tranny...etc.)
rgrafton is offline   Reply With Quote
Old 06-30-2020, 11:25 PM   #2
billr
Default Re: Changing power steering fluid
I'm confused: Could you not reach to get it all out of the reservoir? Or, did you get it all out but were surprised that was only 8 oz.
I did a quickie measurement of the outside on my '94, and it only came to about 16 oz. That doesn't account for wall thickness or radii, or for required empty space above the fluid. Eight oz. seems reasonable to me.
Hint: having the pump running and turning the wheel will have no effect on the reservoir level once the system has been running a while and all air is purged.
Old 07-01-2020, 12:04 AM   #3
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
I put a Wix 33033 filter in the return line of my power steering reservoir...
Pennzoil Maximum Power 0W-30, Champion COS3600...
NGK BKR6E-11 spark plugs
Old 07-01-2020, 07:08 AM   #4
454cid
Why not use a power steering filter? Cardone and a few other companies make/market them. I have a Cardone on my truck. They're even supposed to be cleanable. I think they come apart with a snap ring.
1999 Chevy K3500
Old 07-01-2020, 11:04 AM   #5
mattwithcats
Power steering filter is a rock catcher, 200-250 micron...
Wix 33033 is 15 micron...
Old 07-01-2020, 06:40 PM   #6
454cid
15 microns, designed for a completely different fluid, flowing at a much lower temperature. Have you ever cut one open after using it that way?
1999 Chevy K3500
Old 07-01-2020, 07:45 PM   #7
rgrafton
rgrafton's Avatar
2002 SC1
Good point. I could see more in the back side of the reservoir but I guess my baster was too large to fit back there lol. I guess 16oz makes sense. I didn't realize that back part held 8 more ounces
Old 07-03-2020, 02:31 PM   #8
hholbein
1997 SW2
It took me 4 or so cycles of reservoir drain/replace to fully replace the old cruddy DEX 3 atf with synthetic Dex 3. Since then, no issues.
Brake fluid and power steering fluid leaks sited pierrot L-Series General 40 03-31-2017 12:38 PM
Brake fluid mixed in with power steering fluid! toggenburg S-Series General 6 12-22-2016 01:49 PM
Brake fluid mixed into the power steering fluid sump! toggenburg L-Series General 1 12-21-2016 05:47 PM
Changing your Power Steering Fluid -- tool tip hholbein S-Series Tech 29 11-10-2010 09:24 PM
Question about changing the power steering fluid? turbobuick33 S-Series Tech 2 07-27-2007 11:07 AM
