Old 04-16-2009, 11:12 AM   #1
notmycity
notmycity is on a distinguished road
1999 SL1
Default 1999 SL 1 “jerky” under load --EGR valve?
1999 SL 1 “jerky” under load EGR valve?
1999 SL 1 “jerky” under load about 45-50mph. EGR valve?
We’re also getting a pretty noticeable clunk from the tranny while shifting when it’s cold, usually under 35 mph.
Any thoughts appreciated.
Thanks.
My SL 1 will do 0 to 60 in under two minutes! (Under one minute going down a hill).
Seriously though, love the mpg...
notmycity is offline   Reply With Quote
Old 04-22-2009, 08:28 PM   #2
Bob K
Bob K has a spectacular aura aboutBob K has a spectacular aura about
Default Re: 1999 SL 1 “jerky” under load --EGR valve?
Sure. EGR valve is possible. I had the same issue with my '93 SC2 at 35-45 mph. Kind of a miss that went away at lower or higher speeds.
Your transmission may need a new valve body. Just do a search for "valve body" or "reverse slam" and prepare for some heavy reading.
Bob K is offline   Reply With Quote
Old 04-22-2009, 09:50 PM   #3
First, replace the ECTS if you have not done so already. Next perform a test of the EGR. Cut a piece of can that will cover both ports completely under the EGR valve. Put the can piece under the gasket and reinstall the EGR, plug it back in. Now go drive the car and see if it runs better. You will eventually get a code from having the valve blocked off, it takes a while. You can run this way for a day or so but then remove the can. If the car runs better with the EGR blocked then the EGR is in need of a serious cleaning.
Old 04-23-2009, 12:47 AM   #4
rc1488
rc1488's Avatar
Change your tranny fliud and filter. Should be changed every 20k at least.
A fualty or dirty EGR often cuases issues at constant speeds, not under acceleration as much.
Old 04-23-2009, 08:04 AM   #5
JerryHughes
JerryHughes's Avatar
1997 SL
Not in my case. I followed Old Nuc's recommendation about blocking off the EGR and my hesitation stopped. So I replaced the EGR. Problem solved. But, in my case, the only way I could tell the EGR was bad, was when I was accelerating. Upon acceleration, I experienced hesitation---none at constant speed.
Old 04-23-2009, 09:31 AM   #6
rc1488
rc1488's Avatar
Note I said "As much". Ive been around to know there are exceptions.
Also note that the trany fluid and filter replacement was because of the op's clunks when shifting.
Old 04-23-2009, 09:37 AM   #7
scottd9
scottd9 is on a distinguished road
2002 SC1
I have a 2002 SC1. We recently started experiencing clunking/jerking as the car was moving up & down through the gears while driving. We brought our car into a transmission shop and it was discovered that it was one of the Pressure Control Soleinoids. They replaced it and everything has been great since.
scottd9 is offline   Reply With Quote
Old 04-25-2009, 09:31 PM   #8
notmycity
1999 SL1
Appreciate all of the info. I don't have time or the space to do my own work anymore, but I'll share this with my techs.
Good news is the car is under drive train warranty, the bad news is I just got the car back and it's unchanged.
They did however replace a thermal sensor, head gasket and upper motor mount. Doubtful they test drove it as I was able to feel the same problem inside 2 minutes.
Thanks again.
Old 04-25-2009, 09:45 PM   #9
I see they(your mechanic) listened well. If they can not scan for it they can not fix it.
EGR valve P0401 w/01 EGR on 98 SL1 comanche S-Series Tech 4 10-16-2010 10:32 PM
Problem with EGR circiut and EGR valve Daniel111 S-Series Tech 10 01-27-2009 10:08 AM
EGR code but new EGR valve? lg540 S-Series Tech 5 02-26-2007 08:49 PM
1st. Generation S-series EGR valve Vs. 2nd. Generation S-series EGR valve. Token S-Series Tech 4 03-26-2006 11:52 AM
1999 SL1 EGR valve 95-02 will work? Niteshooter S-Series General 6 01-13-2006 12:15 PM
