Old 08-10-2020, 02:53 PM   #1
Kjluedtke
Kjluedtke is on a distinguished road
Default 2001 LW200 2.I2 Liter crack in head
While the car is 20 years old I have had it just a year it has 189,900 miles.
My question is about the head I changed the spark plugs but as I went to install the coil pack I saw the area above the #4 plug had filled up with antifreeze. After checking I realized it was coming from a hair line crack which I believe is from the water jacket to the outside. This had been sealed with radiator sealer. So I added some K-bar to reseal the leak. Yes I'm lucky the crack doesn't go to the cylinder.
My question is has anyone else had this problem? While I have fixed a few problems like passing smog in California the monitor's not being ready forget that drive cycle nonsense or the vibration that starts around 60 mph to 75 mph both now fixed the crack or cracks has me perplexed as to what and how it happened.
Kjluedtke is offline   Reply With Quote
Old 08-15-2020, 10:21 AM   #2
bluesl2
bluesl2's Avatar
Default Re: 2001 LW200 2.I2 Liter crack in head
Some of the S-series had trouble with porous cylinder heads leaking antifreeze into the spark plug holes. I don't really remember if the L-series had this issue but if you are sure it's antifreeze and not engine oil it's a very good possibility. I don't see any other way it could get in there other than that.
Old 08-15-2020, 11:36 AM   #3
02 LW300
02 LW300's Avatar
I have not heard of this as a common problem with this engine. Possibly a freeze crack due to not enough antifreeze. I know in SoCal a lot of people only run water in their cooling systems.
2002 L200/5 loaded, coming attractions B207R and F40, Ion Redline axles will make this work.
So why does a head crack? 1.9 sohc S-Series Tech 41 05-03-2012 11:41 PM
2001 LW200 Timing Chain Failure - Head Damage fish_skier L-Series Tech 10 11-30-2008 10:46 PM
crack in head???? I3eXa S-Series Tech 13 10-18-2007 08:51 AM
no crack found on top of head. roadgrime S-Series Tech 5 09-30-2004 09:42 PM
Crack head - 1996 SL1 mikebean S-Series Tech 4 01-23-2004 09:04 PM
