Old 01-07-2011, 01:33 AM   #1
macinmypocket
macinmypocket is on a distinguished road
Roll Eyes '97 SL2 RPMs drop below normal when slowing
Hello everyone! I've been browsing around the forums for the last year or so, but I finally made an account to ask for some help.
My manual 1997 SL2 with 190k miles has started to dip RPMs below idle, down to as low as 400 any time pressure is released from the gas pedal, bounces back up to 1000-1100 RPM before dropping back down to normal idle at 800 RPM. Here's a video I took: youtu.be/HB9dl3rE0aI
I've scoured these forums for answers, and have noticed a couple people having the same issue, but so far nothing has worked for me.
(For example: 1997 SL2, 5 spd, DOHC. What I am describing happens at normal operating temperature.
In slowing down when approaching an intersection, I will push in the clutch in anticipation of stopping. If I was at higher than cruising RPMs when the clutch is engaged, the RPMs will drop to around 600 and then rev back up to 1000+ before settling down. Then, when I am at idle (sitting at stop light), the idle seems to be right at 810-830. After 10 seconds or so, I will feel the engine ever so slightly shudder. Nothing major, but I've been watching the tach drop to around 780 or so, and then it pops right back to 810-830.)
The list of things I've done so far is:
Replaced PCV Valve
Replaced engine coolant temp sensor (though with another resin tipped one, couldn't find a full brass one, but the original one seemed to be in perfect condition when I removed it)
Replaced air filter
Cleaned throttle body
Cleaned EGR valve
Changed oil
Checked for loose/cracked hoses and subsequently tightened/taped them up
Reset PCM after all of it
All of which I've seen as potential solutions to the issue I'm having, but none of them seem to have worked. The engine sure runs a little smoother and quieter now, but this problem still persists.
Any more ideas? I'm confident that someone here can help!
I'll make sure to go rep all of the incredibly useful guides and posts that've helped me this past year while I'm waiting. Thanks everyone!
Add to macinmypocket's Reputation
Rate the quality of this post and help macinmypocket reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macinmypocket is offline   Reply With Quote
Old 01-07-2011, 01:43 AM   #2
adventureoflink
adventureoflink's Avatar
Default Re: '97 SL2 RPMs drop below normal when slowing
While you had your throttle body off, did you also clean the IAC valve? This'll cause your RPM to dip like this.
As for replacing an ECTS with the resin one, that shouldn't be.. I'd run and not walk from that place. All ECTSes (OEM/dealer or aftermarket) should be brass tipped by now. As to what condition the old one was in, by any chance, did you also check the connector for green corrosion?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Add to adventureoflink's Reputation
Rate the quality of this post and help adventureoflink reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-07-2011, 01:47 AM   #3
macinmypocket
I did clean the IAC valve while I had the throttle body off, I forgot to add that to the list. I'll go hunting for another ECTS tomorrow, I too was surprised that I could only find resin ones, but I figured c'est la vie and got it, but I'm not opposed to looking for another. Thanks for the reply, any more ideas?
Old 01-07-2011, 01:53 AM   #4
adventureoflink
Only other thing I can suggest is R&R the IAC valve and see if that works (but then again you have a manual, it _might_ be the clutch but I'm not 100% sure; I only own the automatic saturn that comes complete with the floor shifter, eww. ).
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 01-07-2011, 02:03 AM   #5
macinmypocket
R&R the IAC valve? I'm not sure what you mean. I could always try just sucking it up and buying a new one if necessary.
Oh, and it's interesting that you mention the clutch, I replaced that 4-5k miles ago, the whole flywheel, disk, pressure plate and throwout bearing, along with replacing the ancient fluid in the tranny with some sweet amsoil fluid.
Old 01-07-2011, 02:07 AM   #6
adventureoflink
Remove and Replace the IAC valve. Take the throttle body back off, take the IAC valve off, put a new one in, then re-install the TB.
Good deal. I was kinda hesitant on suggesting replacing the IAC valve since you cleaned it but the symptoms were still there. however if you replaced it and the symptoms didn't get any better I didn't want you to be out $30 for playing parts bingo either...
97 SL2
DOB: 3/19/97
DOB: 2/4/04
Old 01-07-2011, 02:23 AM   #7
macinmypocket
I'll give it a shot, I need to keep this baby runnin'.
Occasionally parts bingo is the only way to get things done.
Old 02-20-2011, 11:03 PM   #8
Brendo613
Brendo613 will become famous soon enough
Brendo613's Avatar
1996 SW2
Mine has the same problem, even after a complete engine rebuild. Don't waste your money buying an IACV - mine's blocked-off completely in favor of a manual idle setup. Though it's that way for years, the idle surge problem still persists on mine. Have you solved yours? I've definitely had enough of this anomaly
Add to Brendo613's Reputation
Rate the quality of this post and help Brendo613 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Brendo613 is offline   Reply With Quote
Old 02-20-2011, 11:23 PM   #9
macinmypocket
No, unfortunately, I still haven't gotten this solved. It doesn't happen every time I'm in the car, but it still does it occasionally. To be honest, I haven't put any further work into investigation or money into parts, but if anyone else has suggestions, I'm definitely open to trying them!
Old 02-20-2011, 11:40 PM   #10
Brendo613
Brendo613's Avatar
1996 SW2
Hehe understood. I've been living with this for a while now myself, but after a bottom and top end rebuild, it's time to sort out allll these little faults. Best of luck to ye
Old 02-20-2011, 11:43 PM   #11
macinmypocket
If you get your car sorted out, let me know! I'm still up to trying things! Best of luck to ye too!
Old 03-15-2011, 04:28 PM   #12
macinmypocket
Turns out it was the spark plugs. For anyone else having this issue, give that a try!
Old 03-15-2011, 06:39 PM   #13
Brendo613
Brendo613's Avatar
1996 SW2
What ones did you put in? Congrats btw
Old 03-16-2011, 12:48 AM   #14
macinmypocket
NGK Coppers. Some of the best plugs you can buy, and they're about $1.99 each. Real bank breakers, they are
Old 03-16-2011, 06:22 PM   #15
Brendo613
Brendo613's Avatar
1996 SW2
well right on, more mac in your pocket at that price
RPMs do not drop while coasting Kotofeich Ion Tech 20 11-24-2009 12:41 PM
RPMs drop then rise to normal idle after starting s-seriesguy S-Series Tech 1 07-05-2008 07:44 PM
RPMs drop when going to park NVMY03GT Ion Tech 0 01-09-2008 09:24 AM
drop rpms faster? jump454 S-Series Mods 10 12-25-2007 01:14 PM
Normal Operating RPMs 2NDSOUT S-Series Tech 9 05-15-2004 08:16 AM
