Old 06-02-2012, 11:39 AM   #1
termite
termite is on a distinguished road
termite's Avatar
2003 VUE 3.0L
Default Fuel pressure test gauge problem
I was using the fuel pressure gauge #92699 from Harbor Freight http://www.harborfreight.com/fuel-in...ter-92699.html that I bought 2 weeks ago and it kept leaking where the hose goes into the gauge. I was wondering if anyone else had this same problem. I would think that the hose just screws into the gauge. I even tightened it more when it leaked the first time. When I said it leaked, I don't mean dripping, I mean fuel was slowly pouring out! Did I just get one with a bad hose? I can't find my receipt. I hope they don't give me any problems.
It's GOOD to have a spare!
Add to termite's Reputation
Rate the quality of this post and help termite reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
termite is offline   Reply With Quote
Old 06-02-2012, 11:45 AM   #2
fetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nicefetchitfido is just really nice
1996 SC2
1997 SW2
Default Re: Fuel pressure test gauge problem
Use some teflon tape like one of the reviews says to
Originally Posted by HF Reviewer
I put a little teflon tape on the fitting and it worked great, no leaking and consistant readings. Its nice to have around so you dont have to pay a shop to do something simple, but if you lack the common sense to put teflon tape on the threads so it doesnt leak maybe you should not be working on a car.
My collection of S-Series info: "https://drive.google.com/folderview?id=0B5D8XfJgavxrdE5mcHBlMG5rbUU&usp=sharing" (copy & paste between quotes)
Old 06-02-2012, 12:15 PM   #3
fdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud offdryer has much to be proud of
You aren't the first and probably won't be the last to have issues with Harbor Freight products. As hazardous as it is using it, either replace it with or without a receipt or toss it.
About the only solution you may have is when there are multiple hoses to interchange, perhaps you need to check for an O-ring to fit between the hose and gauge? The kit may have only one O-ring...........................
*The CPS is the heart of the entire EFI system. No cps = dead EFI system*
*There's more to a/c than just a few cans of refrigerant*
*There's more to brakes than just replacing parts*
Old 06-02-2012, 12:25 PM   #4
BrandonK
BrandonK is on a distinguished road
Sears sells a nice Actron kit for right around $40. Twice that of the Harbor Freight unit, but it's a much nicer gauge. Like all fuel pressure testers should, the Actron has a pressure relief and bleed off hose. The HF unit doesn't.
Or as all of the reviews say, use some teflon tape. Personally, I would spend the extra 20 on a nicer setup.
Add to BrandonK's Reputation
Rate the quality of this post and help BrandonK reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BrandonK is offline   Reply With Quote
Old 06-02-2012, 01:27 PM   #5
lil_buddy
lil_buddy is on a distinguished road
1997 SC1
I just rented one from autozone.
Add to lil_buddy's Reputation
Rate the quality of this post and help lil_buddy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
lil_buddy is offline   Reply With Quote
Old 06-02-2012, 03:09 PM   #6
OldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud of
Just unscrew the hose at the gauge and put a wrap of teflon tape on it and re-attach. If it is leaking between the fitting and the hose carefully cut the collar off the hose and use a hose clamp. That fixes the leak.
Old 06-02-2012, 04:49 PM   #7
termite
termite's Avatar
2003 VUE 3.0L
I will give teflon tape a try. Thanks for the suggestions.
Old 06-03-2012, 10:17 AM   #8
termite
termite's Avatar
2003 VUE 3.0L
I tried the teflon tape today and the gauge did not leak. I have around 50 PSI on the car while it is running. When finished I took the hose off of the gauge and the tape cleaned off easily. Then for fun I looked at the gauge directions (more thoroughly this time) and at the top of page 5 I saw them say to use pipe compound or teflon tape. Thats what I get for rushing without reading the directions!
Old 06-03-2012, 12:11 PM   #9
Well it was on page 5, after 4 pages of "Safety Warnings". Only on page 3 in the electronic version though.
Your pressure is fine for a 98+ car.
I don't have a fuel pressure gauge, is there a way to check problem fuel pump without dddaaa S-Series Tech 6 08-06-2011 02:09 PM
fuel pressure test port? nitroussaturn Vue Tech 7 11-01-2009 01:00 PM
What is the proper way to do a fuel pressure test? groingo S-Series General 3 07-09-2009 11:20 AM
fuel pressure test que 97sl2 97sl2DOHCaut1.9 S-Series Tech 1 03-13-2009 11:10 PM
Fuel Pressure Gauge came in! jentzsch23 Ion Mods 4 01-26-2007 09:48 AM
