Old 12-08-2015, 11:17 AM   #1
newbievueowner
newbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the roughnewbievueowner is a jewel in the rough
2006 VUE Red Line
Default Monroe Reflex struts on a RL?
Has anyone ever put the Monroe Reflex front struts on a Vue RL? And if so, how did they fit (ie: are they the exact same size) and how did they feel (ie: sloppy, bouncy or good)?
The HCZ strut option is pretty pricey and I'm not sure it's worth it for a 10 year old car....
At the same time I don't want it to drive/handle like a piece of crap after the install of Monroes...
Looking for feedback from any fellow RL owners that may have done this. Tx,
Saturn Vue: The 250 HP tupperware
newbievueowner is offline   Reply With Quote
Old 12-08-2015, 02:39 PM   #2
deca5423
deca5423 will become famous soon enoughdeca5423 will become famous soon enough
2004 VUE Red Line
2006 ION-2 Quad Coupe
Default Re: Monroe Reflex struts on a RL?
I'm running Monroe Reflex both front and back on my 2004. The struts are the same size. As far as I can tell the only difference between the struts on the RL and base Vue is dampening. I bought the car with 90k so I'm not sure how the originals performed, they were pretty well worn. I'm happy with the Monroes overall. You will want new strut mounts too and use your existing springs.
deca5423 is offline   Reply With Quote
Old 12-08-2015, 07:42 PM   #3
Vue6
Vue6's Avatar
2006 VUE Red Line
...I'm using kyb's myself , they are a bit stiffer than stock ,I like them, just my.02, DC
Old 12-09-2015, 02:09 PM   #4
carvinbassplyr
carvinbassplyr is on a distinguished road
2005 VUE Red Line
Do yourself a favor and get the GM Part #15269823 strut mount kit. It'll update your strut mounts to the later design with larger contact area/bearing. I also went with KYB's, but that was based on the fact that I am also installing Megan Racing lowering springs. I put Reflexes on the wife's Commander and they do just fine, but that's a heavier truck with a V8.
carvinbassplyr is offline   Reply With Quote
Old 12-09-2015, 02:29 PM   #5
tomster
tomster is on a distinguished road
2007 VUE 2.2L
The Monroe Reflexes I just put on are a bit stiffer than the stock and ride about an inch higher. Of course, this is comparing to the OEM shocks I removed, which might have worn out some.
I could have gotten KYB from Shock warehouse for a bit less than Monroe, but the KYB's I put on my Cobalt were smaller and thinner than the OEM shocks I replaced.
2007 VUE 2.2 5M
2009 Chevy Cobalt 2.2 5M
tomster is offline   Reply With Quote
Old 12-14-2015, 01:15 PM   #6
newbievueowner
2006 VUE Red Line
So the Reflex didn't make the RL ride any harsher or more abrupt? Because RL's already ride stiffer than the base model (I had one 4 years ago).
Old 12-14-2015, 01:16 PM   #7
newbievueowner
2006 VUE Red Line
What's the difference? I don't seems to have any issue with the strut mounts now.
Old 12-31-2015, 04:49 AM   #8
carvinbassplyr
2005 VUE Red Line
You may already have the updated strut mount design (just noticed you had an 06). The earlier ones had a smaller contact surface area and a smaller/weaker bearing (I believe) which lead to a higher rate of strut mount faluire and clunky suspensions. If your car doesn't already have the update the only way you can do it is with that GM kit as aftermarket kits are missing a few necessary pieces needed for the switch.
Monroe reflex shocks on redline problem 05redline Vue Tech 35 03-31-2015 08:54 PM
4 New Monroe Struts under $100 sallydriver S-Series General 3 03-26-2014 03:24 AM
Monroe Reflex Shocks and Install PortugalFocus Vue General 5 02-22-2014 08:21 PM
My Monroe reflex struts are too stiff lunareclipse02 Vue Tech 6 09-02-2013 12:28 AM
Monroe Reflex Shocks/Struts PCF Vue General 24 05-30-2007 08:05 AM
