Old 09-26-2012, 01:39 PM   #1
Humy
Humy is on a distinguished road
Humy's Avatar
2008 AURA XE
Default 2008 Aura blowing out cold air when stopped, warm air while moving?
Hey dudes,
Topic title says it all, any ideas?
Thanks
Add to Humy's Reputation
Rate the quality of this post and help Humy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Humy is offline   Reply With Quote
Old 09-26-2012, 02:07 PM   #2
Default Re: 2008 Aura blowing out cold air when stopped, warm air while moving?
Try revving the engine to around 2k rpm in neutral and see if a/c still cools.
Old 09-26-2012, 02:59 PM   #3
greenman
2009 AURA XE
Originally Posted by Humy View Post
Hey dudes,
Thanks
It's usually the reverse.
Add to greenman's Reputation
Old 09-26-2012, 03:45 PM   #4
Humy
Humy's Avatar
2008 AURA XE
Forgot to mention, I am trying to get warm air while stopped
Old 09-26-2012, 05:55 PM   #5
carlover
carlover is on a distinguished road
2008 AURA XR
Check your coolant level. Any engine temp issues? You could also have an air void in the coolant system. Have you had the system drained lately?
c
Drive like you mean it, keep the rubber side down.
Add to carlover's Reputation
Rate the quality of this post and help carlover reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
carlover is offline   Reply With Quote
Old 09-26-2012, 07:24 PM   #6
greenman
2009 AURA XE
I had assumed you were talking about the a/c so now it makes sense.
Old 10-03-2012, 08:50 AM   #7
Khellendrose
Khellendrose is on a distinguished road
Khellendrose's Avatar
You have an air pocket stuck in the heater core. Normally this is a result of a coolant change or you simply ran your coolant low. Generally to remove the air pocket you would simply let the system warm up with the radiator cap off and let the thermostat open and close a couple times. This wont always work, so the other way of handling it is by doing this same thing but put the front end up on ramps so the vehicle is at an angle.
My mother had this same issue in her Dodge minivan after the radiator was replaced, every shop was trying the same tactics to to remove the air. Then someone decided to actually look at the system and found that the heater core hoses were hooked up backwards. This top level work was done by a shop in Vernon BC not me lol
Add to Khellendrose's Reputation
Rate the quality of this post and help Khellendrose reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Khellendrose is offline   Reply With Quote
Old 10-03-2012, 02:12 PM   #8
greenman
2009 AURA XE
Radiator caps have gone the way of the dodo bird.
AC blowing warm air without even turned on qkhhly Ion General 4 06-19-2012 11:44 PM
04 Ion 2 - Interior Fans Stopped Blowing vashavoc Ion Tech 1 01-12-2012 04:02 PM
Calling all AC gods! Blowing Warm.... hholbein S-Series Tech 5 07-30-2009 09:00 PM
Heater blowing warm, not hot air. vikingcarguy S-Series Tech 26 03-09-2009 10:01 AM
a/c blowing warm, please help bringles S-Series Tech 1 09-17-2008 10:07 AM
