Go Back   SaturnFans.com Forums > Categories > Classifieds
Old 10-15-2019, 10:40 PM   #1
Default 3.0L V6 used water pump and three idler pulleys
If anyone's interested in rebuilding the water pump and idler pulleys with new bearings, contact me via private messaging. I replaced them when performing a timing belt replacement recently. None the worse for wear after 108k miles but they are used. Even the black oxide coating remains on all three idlers. The core parts are perfect for anyone with access to a bench press and some tools to replace all the bearings. Bearings should be replaced and that shouldn't be a problem to anyone with knowhow. The one O-ring to the water pump may be problem but not for anyone accustomed to searching for specific parts. These four items will remain on my bench until asked otherwise they'll get tossed. All I ask is shipping costs (UPS, postal, whatever). I'll try to update with snapshots later.
Old 10-25-2019, 09:01 PM   #2
Default Re: 3.0L V6 used water pump and three idler pulleys
Snapshots. Coolant corrosion around the water pump seal may have allowed a small leak, less than half a pint per year after 75k(?) miles as I suspected ether the pump seal or two (reused) O-rings on the t-stat extension tube were suspect after t-stat replacement. Idler bearings are not loose but grease oozed out from seals. Pump bearings are tight, not loose.
Worn in grooves on idler and tensioner pulleys Nekomimi S-Series Tech 6 02-09-2018 05:41 PM
Water pump or idler pulley? hit_n_run S-Series General 22 08-07-2007 07:39 AM
Are the idler & belt tensioner pulleys interchangable? auxmike S-Series Tech 3 09-11-2006 01:21 AM
HA! Fixed my idler and tension pulleys for $20! ArghIGiveUp S-Series General 13 04-15-2005 04:12 PM
Timing chain / Idler pulley / water pump questions. Spazie S-Series Tech 6 11-16-2003 04:41 AM
