Old 12-20-2017, 06:38 PM   #1
FrankieTNK
FrankieTNK is on a distinguished road
Default Rims
Really need to know what's the biggest size rim that could fit on a 2003 Saturn Vue ? And if possible what tire size will best fit with rim sizes of 20" ? Really would appreciate the information soon looking to get the Vue ready before spring.
Add to FrankieTNK's Reputation
Rate the quality of this post and help FrankieTNK reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FrankieTNK is offline   Reply With Quote
Old 12-20-2017, 11:24 PM   #2
SylenThunder
SylenThunder's Avatar
2003 VUE 2.2L
Default Re: Rims
IMHO, you shouldn't use anything larger than an 18" wheel for the Vue.
Larger than that is solely for looks, and will be a detriment to the handling and driveability of the car. (Also, your gas mileage is going to suck balls if you stick 20's on it.)
Theoretically, you could use a 20x8.5. You'll need to double-check fitment with the tires on it though, as it may rub in the fender. 20x8 should fit for sure.
2004 FWD, Vti, 2.2L
Custom CAI
Add to SylenThunder's Reputation
Rate the quality of this post and help SylenThunder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SylenThunder is offline   Reply With Quote
Old 01-24-2018, 01:00 PM   #3
Cavell
2004 VUE 3.5L
Default Re: Rims
235/65/16 tire is 28" OD
235/45/20=28.3"
using a rim with similar offset and WIDTH and it will fit fine
do the math.
a 21" rim and 40 series tire will work
a 22" rim with 35 series tire will work
these number are APPROXIMATE
do the math
Add to Cavell's Reputation
Old 02-20-2018, 07:46 PM   #4
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: Rims
...I'M USING 20'' SRT8 RIMS WITH 245 45 20 TIRES,RIMS ARE ALCOA FORGED AND LIGHTER THAN MY 18 INCH REDLINE RIMS, JUST MY .02, DC
Add to Vue6's Reputation
Rate the quality of this post and help Vue6 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 02-20-2018, 09:18 PM   #5
Finkle
Finkle is on a distinguished road
Default Re: Rims
I tried 20" mustang rims on mine, and it looked off, plus with the small tires, they were actually too small for the Vue. I have 18s now. FWIW Chrysler 300 rims of certain years fit perfectly in terms of bolt pattern and hub diameter. Its hard to find rims that don't need hub centric rims.
Add to Finkle's Reputation
Rate the quality of this post and help Finkle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Finkle is offline   Reply With Quote
Old 02-24-2018, 09:58 AM   #6
blaster88
blaster88 is on a distinguished road
2004 VUE Red Line
Default Re: Rims
PO of my Redline put on 20 in rims - they must be 8 inch, 0 tires are 245/35/20
Brand of the rim is Motiv I think.
Add to blaster88's Reputation
Rate the quality of this post and help blaster88 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blaster88 is offline   Reply With Quote
Old 03-06-2018, 03:08 PM   #7
blaster88
2004 VUE Red Line
Default Re: Rims
Looked them up - actually 20 x 10 rims.
Also, doing the math on those 20s, the OD is somewhat smaller than the OE tire for RL.
Old 03-15-2018, 09:19 AM   #8
Vue6
Vue6's Avatar
2006 VUE Red Line
Default Re: Rims
...ON MY TIRES ,245 45 20 ,THE DIAMETER IS LARGER THAN THE FACTORY 245 50 18 , JUST MY.02, DC
Old 12-13-2018, 12:42 PM   #9
redlinevue
redlinevue will become famous soon enough
redlinevue's Avatar
2004 VUE 3.5L
Default Re: Rims
My '04 V6 has had 255/45/20's on it since 2005 and I now have over 217k miles on it.... I average 23mpg with city/hwy mix and it doesn't ever rub unless I just about making a full lock uturn and go over a speed bump. Pretty sure thats a large as I'd go but I think it worked great in my case.
Add to redlinevue's Reputation
Rate the quality of this post and help redlinevue reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
redlinevue is offline   Reply With Quote
Using 14" or 15" rims from older ION on 2006 ION QC -what older rims will fit ? ws6formula Ion General 11 12-26-2007 05:35 PM
lightweight track rims, normal weight street rims dragon370 S-Series Mods 49 05-23-2007 01:15 AM
2002 AWD V6 16in rims to 17in rims KoolVue Vue Tech 3 02-02-2007 09:53 PM
will these rims fit, or what size rims fit mad_nigerian S-Series Mods 6 04-24-2006 09:01 AM
WTB: set of L300 15" rims alloy rims w/o tires Steve02 Classifieds 8 06-05-2004 06:58 AM
