Old 11-09-2004, 02:32 PM   #21
playboyroy
playboyroy is on a distinguished road
Default Re: Service Engine Soon - P0171 & P0174 HELP?
Here is what I would do. Since you most likely have to pay for the diagnostic charge of having tech look at your vehicle. Have them update your ECM calibration if needed. Most shop don't charge you the diagnostic charge if you get some work done. I would try to ***** for them to do it for free. New calibrations are common to improve performance and issues. It's like new updates for windows on your home computer.
Buy the parts yourself and install them. If you changed your air filter before, you have removed and installed your MAF sensor. As for throttle body, if you don't feel comfortable doing, if someone to do it for you. It's simple to do in your driveway. Some here could give you the procedure if needed.
As for the codes, once the ECM notices the issue has been fixed it will turn off the engine light. After many ignition cycles, it will erase the code. Or you could slip the Autozone person a couple of bucks to erase them. Cash is king.
Add to playboyroy's Reputation
Rate the quality of this post and help playboyroy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
playboyroy is offline
Old 11-09-2004, 03:07 PM   #22
filter905
filter905 is on a distinguished road
Anyone know how to change the Throttle Body? At least a step-by step instruction on how to do it. I've got a mechanic in mind that can help me change it. THE MAF I can do myself, I'll drive to any place that has a ECM Diagnostic Machine so they can upgrade the computer. I'll take the chance...do it myself in changing the parts.
Thanks Folks...
Add to filter905's Reputation
Rate the quality of this post and help filter905 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
filter905 is offline
Old 04-27-2005, 11:21 PM   #23
beensmoked
beensmoked will become famous soon enough
2001 L-Series 3.0L Sedan
2002 L-Series 2.2L Sedan
Originally Posted by lostwages_ls2
P1511 is a throttle body code. Could be weak return spring. Bad sensor. Or butterfly is binding.
The book standard labor to replace the throttle body is .9 hours. You are being overcharged by .5 hours for that. $360 for the part is about right.
Any garage with the right equipment to "recalibrate" the ECM can do it.
Actually if you are mildly mechanically inclined, you could probably replace the parts, then drive it to the dealer for recalibration. It may not drive perfectly, but it should get there.
alrite i know this is an old thread..but i just recently replaced my MAF sensor...do i need to get my car recalibrated?
Add to beensmoked's Reputation
Rate the quality of this post and help beensmoked reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
beensmoked is offline
Old 04-28-2005, 12:16 AM   #24
btrautman
btrautman is on a distinguished road
Originally Posted by programmer12
Thanks, I'll try the injector cleaner. I had the guy from autozone clear the code and boom five minutes later it went on again.
I'll get the injector cleaner.
Can the MAF be cleaned? It seems like a mechanical sensor. Wire heats up....
They must be able to thoroughly clean it at the factory when manufacturing the part, so couldn't I clean it also. With like a Qtip and alcohol.?
IS it worth a try. HOw do I keep it from getting dirty again? A dealer should reprogram my car to not heat up the maf after the engine is shut off so it won't attract oil to contaminate it.
Spray brake cleaner on MAF and let it dry... do not touch the wire.
Bob
Add to btrautman's Reputation
Rate the quality of this post and help btrautman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
btrautman is offline
Old 04-28-2005, 11:40 AM   #25
L300Boy
L300Boy is on a distinguished road
L300Boy's Avatar
This did not fix my SES issues with these codes...and the wire is pretty clean now.
I am pretty certain I am experiencing a sensor issue, as it will run rough on inital startup, i can restart it at any time, and it runs perfectly.
Add to L300Boy's Reputation
Rate the quality of this post and help L300Boy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L300Boy is offline
Old 04-28-2005, 02:44 PM   #26
slo5oh
slo5oh is on a distinguished road
Did you reset your ECU? I did the same... cleaned my MAF, then reset the ECU and the SES never came back. I had already ordered a new MAF, so I replaced it a week later with the new one and the car drives like new again.
Add to slo5oh's Reputation
Rate the quality of this post and help slo5oh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slo5oh is offline
Old 05-01-2005, 10:45 AM   #27
Garciavision
Garciavision is on a distinguished road
Garciavision's Avatar
2001 L-Series 3.0L Wagon
I got hit for $518 for MAF sensor replace anf Throttle body and injector cleam. This was last november 8 mos after 3 yr warranty ran out. I took tip from lostwages ls2 and went to Saturn Dealer about known problem and TSB details. Now I read on another thread 7 yr Warranty on Transmission control module. Is this justifialbe claim for refund
Add to Garciavision's Reputation
Rate the quality of this post and help Garciavision reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Garciavision is offline
P0171 P0174 codes on 3.0 Vue IMkenNY Vue Tech 4 04-03-2009 06:05 AM
vacuum chamber springs? p0171 p0174 vue092107 Vue Tech 3 01-15-2009 09:39 PM
P0507, P0171, P0174 (3.0 V-6 L81) wfransee Vue Tech 1 12-20-2007 06:57 PM
Need advice - P0171 & P0174 Hakman L-Series Tech 8 07-05-2007 03:01 AM
Service Engine Soon P0171 & P0174 HELP? programmer12 L-Series Tech 11 09-01-2004 12:39 AM
