Old 10-12-2015, 08:23 PM   #1
goob
goob is on a distinguished road
Default what are the timing belt tensioner bolt and idler pulley bolt torque values
Help, can someone please tell me what the correct torque values are for these two bolts. I changed my timing belt yesterday using the Haynes manual which stated 15 lb/ft. for the timing belt tensioner bolt and 18 lb/ft for the idler pulley bolt. I used red thread locker on both. The car seems to run fine. Today i read the little instruction page that came with the Gates timing belt kit. It states that the tensioner bolt should be torqued to 40 lbs/ft and 37 lbs/ft for the idler bolt. Quite a difference from the Haynes values and they aren't even proportional to each other. Now i'm trying to find if i need to tear everything back down to tighten up those bolts. Can someone confirm what the correct values are.
Thanks, Gary
08 Salsa Red Astra XR 5dr 5spd
Spt Pkg, Prem. Aud. and Sunroof
goob is offline   Reply With Quote
Old 10-13-2015, 01:18 AM   #2
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
Default Re: what are the timing belt tensioner bolt and idler pulley bolt torque values
Cylinder Head Timing Belt Tensioner
20 Nm
15 lb ft
Cylinder Head Timing Belt Deflection Pulley
25 Nm
18 lb ft
Old 10-13-2015, 10:23 AM   #3
goob
20 Nm
15 lb ft
25 Nm
18 lb ft
Thanks Bern for the info. This certainly puts my mind at ease. If you don't mind me asking, what is the source of your info?
Gary
Old 10-14-2015, 01:03 AM   #4
bern
2004 ION-2 Sedan
GM SI (General motors service information)
Old 10-14-2015, 08:05 PM   #5
goob
Perfect, Thanks so much!
subframe bolt torque; belt tensioner MikeNW S-Series Tech 5 10-17-2013 12:41 PM
Size of idler pulley bolt poulsbro S-Series Tech 1 08-24-2012 10:36 PM
97 sl2 idler pulley bolt big w S-Series Tech 0 04-12-2012 04:17 PM
Are the serp belt idler pulley and tensioner pulley the same part - 93 DOHC?? 93goldsl2 S-Series Tech 6 04-10-2010 02:03 PM
Tensioner/Idler pulley bolt torque pimpin88 S-Series Tech 4 01-31-2009 05:05 PM
