Old 10-05-2013, 01:49 PM   #1
IamPlanB
IamPlanB is on a distinguished road
2008 Astra XR
Default new member needs help
hi everyone. im currently working on my neighbors 2008 saturn astra xr .
she bought with 35,000 miles and it currently has 70,000.
she brought to me, with check engine light on and a noisy engine noise, more like knocking similar to a diesel engine.
P0068
P0011
got these codes, check the MAF sensor for first code, noticed it had K&N filter
cleaned it , very very light oil on filter, clean sensor.
second code , pulled the solenoid from intake side and noticed it did not have the screens that i have heard on here its supposed to have, exhaust solenoid didnt have either.
replaced solenoid with new one , fresh oil change with filter
reset codes, and BOOM
still same problems, same codes, still sluggish take off, and still loud knocking noise.
remove valve cover, because it sounds like lifter is making that loud noise.
but could not identify problem.
please need help. i know what im doing , i can work on cars and fix them, but sometimes i get caught up like this time.
btw . before working on car, when on start up is when knocking sound started
but would go away then back when warm
now , when start up is fine , but knocking sounds come back little at first then continuously after warm up and sets fault code back on
is the purge valve supposed to make so damn loud noise as well?
Add to IamPlanB's Reputation
Rate the quality of this post and help IamPlanB reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IamPlanB is offline   Reply With Quote
Old 10-05-2013, 04:49 PM   #2
IamPlanB
2008 Astra XR
Default Re: new member needs help
Forgot to mention that it had a stored DTC
P0016. Crankshaft position , camshaft position correlation. Bank 1 sensor A
Old 10-06-2013, 11:48 PM   #3
IamPlanB
2008 Astra XR
nobody has anything that might help me out here?!
Old 10-06-2013, 11:56 PM   #4
billysvue
Maybe timing belt? slipped a cog and valves and pistons are tapdancing on each other..engine may self-destruct any moment?
"knocking"- mechanical like piston slap or more detonation type ? oil register on the dipstick? compression check all around?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 10-07-2013, 02:53 AM   #5
IamPlanB
2008 Astra XR
doesnt sound like piston slap or detonation. hard to describe, sounds like loud
"tick-tick-tick-tick-......."
was gonna start looking into possible skipped tooth on timing belt, inspect belt adjuster and check if cams and crank match at TDC.
Old 10-07-2013, 03:06 AM   #6
IamPlanB
2008 Astra XR
removed top timing cover and started engine, and intake cam gear looked like it spins a little "wobbly"?
check engine came back on reading 3 codes when before i was just only getting 2 codes; P0011, P0068.
now im getting P000A. engine position system performance, bank 1
i replaced the camshaft position actuator solenoid. the solenoid allows the oil to enter the actuator that is able to change the timing of the camshaft up to 20 degrees.......... where is the actual actuator?
Old 10-07-2013, 01:46 PM   #7
goob
goob is on a distinguished road
Hi,
My car had the same symptoms (sounded like a diesel, loss of power).
The dealer replaced the Intake Solenoid sensor part # (55567050).
This was covered under the powertrain warranty. Not sure this pertains to a 2nd owner.
Is this the part you replaced?
Gary
08 Salsa Red Astra XR 5dr 5spd
Spt Pkg, Prem. Aud. and Sunroof
Add to goob's Reputation
Rate the quality of this post and help goob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
goob is offline   Reply With Quote
Old 10-12-2013, 12:25 AM   #8
smwalker
smwalker has a spectacular aura aboutsmwalker has a spectacular aura aboutsmwalker has a spectacular aura about
2008 Astra XR
Did you check the condition of the spark plugs? Know the history of replacement?
Add to smwalker's Reputation
Rate the quality of this post and help smwalker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
smwalker is offline   Reply With Quote
Old 10-27-2013, 08:08 PM   #9
mkchel
mkchel is on a distinguished road
2008 Astra XR
Dizzy Re: new member needs help
My 08 Astra XR is having similar issues with miss firing....was told I need new spark plugs and new coil packs at $700 from dealer? I get a lot of choppy acceleration though, so not sure this is the right fix - hoping to hop onto your thread here and get some help. PC0304 is the code that's getting thrown.
Anyone???
Add to mkchel's Reputation
Rate the quality of this post and help mkchel reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mkchel is offline   Reply With Quote
Old 10-27-2013, 09:35 PM   #10
Astra La Vista!
Astra La Vista! has a spectacular aura aboutAstra La Vista! has a spectacular aura about
Astra La Vista!'s Avatar
2008 Astra XR
Anyone???
When a dealer recommends both plugs and the coil pack, it sounds to me like they're just chucking parts at it -- unless the plugs are badly worn to begin with. If they install the coil pack and it still doesn't solve the issue, don't fall for the old "your car needs plugs and a coil pack and (something else)..."
If they are certain that the coil pack is the cause of the problem, you should know that you can purchase one aftermarket for a lot less, and it only requires a few basic tools to swap out yourself.
"That's a Hruck Bugbear, manufactured in Eastern Europe in the eighties and imported to the States. People mock it as a poor man's Yugo. I consider it the pinnacle of Cold War Balkan engineering."
Add to Astra La Vista!'s Reputation
Rate the quality of this post and help Astra La Vista! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Astra La Vista! is offline   Reply With Quote
Old 01-29-2014, 07:15 PM   #11
julz1962
julz1962 is on a distinguished road
Did IamPlanB work it out???
My 2004 Saturn VUE Redline is doing the same thing and the codes it registers says all my injectors are miss firing which did not pan out when they checked it.
It ticks at start up and then warm up and be fine but a knocking noise will present itself when idling after running for awhile. It appears to be on the left side (hood open looking in).
Someone help?
Thanks
Add to julz1962's Reputation
Rate the quality of this post and help julz1962 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
julz1962 is offline   Reply With Quote
New car, New member. Stlrams513 Aura General 9 01-28-2011 07:17 PM
New Member! Breezepimp98 Introductions & Greetings 5 08-11-2009 07:45 PM
Greetings from New Member! Alex-SW2 S-Series General 6 01-23-2007 07:20 PM
Hi, New Member needs your help C130Flyboy S-Series General 0 08-14-2006 10:33 AM
New Member TW1 S-Series General 10 03-13-2005 07:23 PM
