Old 05-21-2004, 05:27 AM   #1
Bigbadbert
Bigbadbert is on a distinguished road
Bigbadbert's Avatar
Roll Eyes Stripped bolt head
Ok me and a buddy of mine were trying to get off my water pump pulley, and one of the bolt heads decided to strip for some reason. The other two came off no sweat. Is there a good way to get this thing off, and get it back on tight? Id appreciate any help.
'01 SC2 - sold
Add to Bigbadbert's Reputation
Rate the quality of this post and help Bigbadbert reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bigbadbert is offline
Old 05-21-2004, 05:55 AM   #2
Bigbadbert
Bigbadbert's Avatar
Default
Ok I cant edit it but it should say that we rounded off the head rather than stripped it.
'01 SC2 - sold
Old 05-21-2004, 06:39 AM   #3
Spazie
Spazie will become famous soon enough
Spazie's Avatar
1993 SC2
Default
Robo-grips, or a strap wrench maybe?
13 Chevy Equinox, 46k, built in Spring Hill!
04 VUE 3.5, 196k
99 SL2 Homecoming, 211k
Add to Spazie's Reputation
Rate the quality of this post and help Spazie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Spazie is offline
Old 05-21-2004, 07:44 AM   #4
gm7
gm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the roughgm7 is a jewel in the rough
gm7's Avatar
2009 VUE Red Line
Default
a few options Bert...try vice grips first of course...the bolt for the water pump shouldn't be torqued too tight. You can take a dremel drill and grind each side of the bolt head down to create a longer parallel flat than was on the hex before...creating more of rectangular bolt head with two long flat parallel sides. Then turn down a large crescent wrench and put it over the rectangular bolt head and loosen. Worse case you can cut off the head of the bolt with a dremmel cut off wheel or hack saw, remove the water pump and then take a pair of vice grips and unscrew the now unloaded shank of the old bolt.
HTH,
George
Add to gm7's Reputation
Rate the quality of this post and help gm7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gm7 is offline
Old 05-21-2004, 08:39 AM   #5
mars_volta
mars_volta is on a distinguished road
mars_volta's Avatar
Default
Yep, dremel to the rescue!
MV
Add to mars_volta's Reputation
Rate the quality of this post and help mars_volta reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mars_volta is offline
Old 05-21-2004, 09:04 AM   #6
planet6racing
planet6racing is on a distinguished road
planet6racing's Avatar
1992 SL2
1992 SL2
Default
Sears Craftsmen Bolt Extractor. Hands down the best bolt extractor I have ever used. When used correctly, it will remove it no matter what the head condition is.
Bill
Planet 6 Racing
SCCA ITA #92
Add to planet6racing's Reputation
Rate the quality of this post and help planet6racing reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
planet6racing is offline
Old 05-21-2004, 03:41 PM   #7
JayNYC
JayNYC is on a distinguished road
Default
Bolt extractors work well (sears tool that you will probably use twice) I have experience that involves a long story involving a battery LOL. I wouldn't plan on putting the bolt back on though. A new bolt shouldbt be too expensive ( under $1.25)
Add to JayNYC's Reputation
Rate the quality of this post and help JayNYC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JayNYC is offline
Old 05-21-2004, 10:54 PM   #8
Bigbadbert
Bigbadbert's Avatar
Default
Ok, will that bolt extractor work in that SMALL area? Theres very little space at all between the frame and the bolts. If you have to use a ratchet, its too big to fit up in there, unless Im completely missing something. I might just go with the dremel and purchase the extractor anyways. Im always playing with my car, so Ill probably need it again. Thanks for the ideas.
'01 SC2 - sold
Old 05-21-2004, 11:37 PM   #9
ym42
ym42 is on a distinguished road
Default
As far as I remember you can take the whole water pump with the pulley off the car, and then work with it at home, or your garage. Those bolts were very hard to work with, I remember still. I used LARGE vice!!!
Add to ym42's Reputation
Rate the quality of this post and help ym42 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ym42 is offline
Old 05-22-2004, 12:43 AM   #10
MaxSL2
MaxSL2 is on a distinguished road
MaxSL2's Avatar
2003 VUE 2.2L
Default
The bolt extractor is a socket. If you can't pull the pump off the car first, possibly some needle-nosed vise grips (the cheap brand ones slip off too easily for this purpose) locked very tightly on the remaning head might work, just use the alternating loosen -then-tighten method to help get it to turn.
Soaking it good with a little PB Blaster might make it want to break loose a little easier also.
Add to MaxSL2's Reputation
Rate the quality of this post and help MaxSL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MaxSL2 is offline
Old 05-22-2004, 03:54 AM   #11
Bigbadbert
Bigbadbert's Avatar
Default
I bought of some of that tonight. I will probably let that soak on there while Im working on the stupid crank pulley. Man those things are on there.....thanks for the tips guys!
'01 SC2 - sold
Stripped Oil Pan Bolt - HELP! travisj027 S-Series Tech 16 07-14-2012 10:35 AM
HELP! Fatty caliper bolt stuck and stripped! demoncamber S-Series Tech 8 09-20-2009 01:40 PM
Stripped bolt??? duganator9 S-Series Tech 18 11-16-2007 07:22 PM
stripped bolt, someone help! cmac212 S-Series Tech 9 01-15-2007 10:03 PM
help! stripped bolt diestrutionomeg Miscellaneous Tech 8 07-24-2004 08:00 AM
