Old 09-08-2007, 08:46 AM   #1
94503
94503 is on a distinguished road
Default wondering what diodes can be put in to get the best timing curve and fuel curve
i saw a post on here awhile ago about putting diodes in where the cts is and the ait is but there are certain ones to put in that give you th best timing and fuel curves
Add to 94503's Reputation
Rate the quality of this post and help 94503 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
94503 is offline   Reply With Quote
Old 09-08-2007, 10:37 AM   #2
amazinghl
Default Re: wondering what diodes can be put in to get the best timing curve and fuel curve
Leave it alone. Diodes will only make your car runs worst, not better.
00 Insight 72mpg
Add to amazinghl's Reputation
Old 09-08-2007, 10:56 AM   #3
Low Saturn
Low Saturn's Avatar
2000 SC2
Actually diodes wont do anything. If installed correctly, a diode wont do anything. If installed backwards the car either wont run at all or will run poorly. Its resistors that people use. And all the does is cause the engine to run richer than it already does.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 09-08-2007, 01:11 PM   #4
pascal_ladale
pascal_ladale is on a distinguished road
2008 Astra XR
a correctly installed diode will let the current pass throught it but it will lower the voltage of 1.3V to 1.7V depending on the type of diode used.
Add to pascal_ladale's Reputation
Rate the quality of this post and help pascal_ladale reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
pascal_ladale is offline   Reply With Quote
Old 09-08-2007, 01:55 PM   #5
Uzzy
Uzzy's Avatar
2002 SC1
No it won't. That's the voltage drop across the diode that switches it on, not the voltage it allows through the circuit. A diode is not a voltage limiting device, it is a channeling device.
Anyhoo, as Low Saturn said, it's resistors people use, and they don't fine tune them for fuel maps, they think they are buying "chips" and are just buying resisitors that fool the computer into thinking it is getting super cool air all the time. The benefit is little and the consequences greatly outweigh them. Things like: poor fuel economy, wasted fuel, carbon deposits from unburn fuel and damaged catalytic convertors.
Aut viam inveniam aut faciam
Add to Uzzy's Reputation
Old 09-08-2007, 02:08 PM   #6
geartooth94
geartooth94's Avatar
well then those people must never have heard of the "JDM" - style performance chips. an increase of 30 hp is guaranteed!
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 09-08-2007, 02:30 PM   #7
Uzzy
Uzzy's Avatar
2002 SC1
The problem with conversing on the net is you can't hear the cynicsm or sarcasm in a person's typing, such as in the above post.
Old 09-08-2007, 02:36 PM   #8
I'd spend $5 on a potentiometer (sp?) before I spent $5 on a bag of RadioShack resistors or the eGay "chip." Least with the potentiometer I can "change" the "air temp" while in the car.
Old 09-08-2007, 05:07 PM   #9
geartooth94
YAY!!!
Old 09-08-2007, 06:03 PM   #10
Uzzy
Uzzy's Avatar
2002 SC1
^^^ There you go, get the car some pot and it'll run faster
Old 09-08-2007, 06:13 PM   #11
johnny95sl2
johnny95sl2 will become famous soon enough
johnny95sl2's Avatar
1997 SW2
UUUmmmmm pot...brings back the old days. At least what I can remember of them
Add to johnny95sl2's Reputation
Rate the quality of this post and help johnny95sl2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
johnny95sl2 is offline   Reply With Quote
Old 09-09-2007, 02:02 PM   #12
sl_don
sl_don is on a distinguished road
sl_don's Avatar
2004 VUE 3.5L
on top of the marginal effects this mod may have it will only be while the engine temp is cold. once the engine has reached operating temp it switches to closed loop operation. in other words it pretty much ignores most of the sensors and uses predetermined values stored in the PCM. so you are wasting your time with this mod and chances are more likely that you will screw something up than make more power.
If it isn't broken.........Your not trying hard enough
2002 SL first brand new car in my family since the 1981 Pontiac Phoenix (sold)
2004 Vue AWD V6 bought used (current)
Add to sl_don's Reputation
Rate the quality of this post and help sl_don reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sl_don is offline   Reply With Quote
Old 09-09-2007, 02:07 PM   #13
Low Saturn
Low Saturn's Avatar
2000 SC2
Reverse that.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 09-09-2007, 02:33 PM   #14
quiksc2
quiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura aboutquiksc2 has a spectacular aura about
quiksc2's Avatar
2002 L-Series 3.0L Sedan
Originally Posted by Low Saturn View Post
Reverse that.
That's what I was gonna say..
If I wanted ride quality, I would drive a Cadillac. If I wanted to be a sheep, I would drive something that says Vtec on the side of it...
DCS
Add to quiksc2's Reputation
Rate the quality of this post and help quiksc2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quiksc2 is offline   Reply With Quote
Old 09-10-2007, 11:15 PM   #15
eRic 02sc2
eRic 02sc2's Avatar
Did someone say pot? Yes, please. Actually a company Select Sales was selling some pots with an air-fuel meter that you could use to 'tune' the car by messing with the coolant temp sensor signal. There was an article on it in Grassroots Motorsports magazine a few years back. They got some fuel enrichment from it by making the PCM think the engine was cooler.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 09-11-2007, 02:57 AM   #16
quiksc2
quiksc2's Avatar
There's an article about doing it with a Jeep or something. Same idea. I have the link on my other computer. I'll post it.
DCS
Ever Seen this Saturn?? Curve?? l0phat S-Series General 12 11-13-2009 07:16 PM
Boost Curve 77Ronin Ion Red Line 0 03-22-2006 02:24 PM
Torque Curve TDuck S-Series General 10 09-10-2004 12:00 PM
Curve or Redline? bigad21 General Saturn Discussion 23 03-01-2004 12:46 AM
