Old 08-18-2013, 11:33 AM   #1
bk63
bk63 is on a distinguished road
Default Rear coil spring broken
I've never seen this before, but I have been hearing a "bong" sound when taking left turns. I rotated my tires today and noticed while looking for this noise the coil spring is broken at the base. Looks like it rusted away. It looks like an easy fix. Anybody do this before? I assume if I take one bolt off the lower arm and lower it with a jack I can get this out and replace? Any help is appreciated. Thanks.
bk63 is offline   Reply With Quote
Old 08-18-2013, 02:22 PM   #2
gaurdien
gaurdien will become famous soon enough
gaurdien's Avatar
2008 Astra XR
Default Re: Rear coil spring broken
Yes I had this on both springs. Would take a look at the other one as well. Got both springs through a GM dealer. Basically jack the rear up and support it. Take the rear shock bolt out to release the arm. Pull out old spring and put new one in. I had to use the floor jack under the arm to get it back into place to reinstall the shock.
Good things are happening..........., somewhere.
gaurdien is offline   Reply With Quote
Old 08-24-2013, 07:31 PM   #3
bk63
Well I seriously have to question if you actually did this I have to call BS. There is no way you can simply pull the rear shock off and get this spring out because I did it today and it's a PITA! I also had to take a bolt out of the rear support arm and pull a bolt out of the sway bar and then it was still a PITA to get the coil spring out. No way no how you can simply disconnect the rear shock and get this coil spring out, ever!
Old 08-26-2013, 06:48 PM   #4
PortugalFocus
PortugalFocus's Avatar
Most guys pay good money to lower their VUEs and you got it done for free. Broken coils springs are old school. I wouldn't complain.
Old 08-26-2013, 07:40 PM   #5
bk63
Wow, what an intelligent reply!
Old 08-27-2013, 11:44 AM   #6
PortugalFocus
Clearly in jest.
Old 09-02-2013, 07:44 AM   #7
gaurdien
gaurdien's Avatar
2008 Astra XR
Bk. A bit on the aggressive side there towards me. I am relating my experience on my vehicle. It is a front wheel drive so it's a very simple area back there. Is yours an awd? If so maybe that explains the different experience. I also know others have posted here on fixing stuff that they said was easy for them to do but took a little bit more of an effort or time investment on my part. Didn't feel the need to call them bsers.
broken coil spring scotttomlin S-Series Tech 14 07-17-2014 06:20 PM
Broken Rear Coil Spring and Control Arm Rivernut Vue Tech 0 01-23-2012 05:24 PM
Broken Coil Spring help, please. HV Fam Wagon L-Series Tech 6 07-04-2011 02:18 PM
Broken front coil spring catd47u S-Series General 8 05-09-2008 06:01 PM
Broken front coil spring catd47u L-Series General 2 05-08-2008 12:51 PM
