Old 07-29-2010, 01:36 PM   #1
300maximilien
300maximilien is on a distinguished road
300maximilien's Avatar
2002 VUE 3.0L
Default Broken Rear Spring...common??
Today I was replacing a right rear hub assembly on the GF's '02 Vue V6 and noticed that the coil spring was snapped on the upper most coil. Is this common? Any leads on aftermarket springs. Or is this a Dealer item. I checked online parts stores and come up empty
Anyone know the OEM part # 2002 Vue V6 AWD
2002 Saturn Vue V-6 81,000 miles
2002 Chrysler 300M Special 115,000 miles
1978 Dodge Li'l Red Express 78,000 miles
1997 Dodge Neon 2dr Sport 130,000 miles
300maximilien is offline   Reply With Quote
Old 07-29-2010, 08:38 PM   #2
termite
termite is a jewel in the roughtermite is a jewel in the roughtermite is a jewel in the rough
termite's Avatar
Default Re: Broken Rear Spring...common??
I remember once making a left turn and I heard a "bang" noise. I looked underneath but could not find anything. This makes me think I should take one more close look. Did your GF ever remember hearing any noise?
It's GOOD to have a spare!
termite is offline   Reply With Quote
Old 07-31-2010, 12:27 PM   #3
300maximilien
2002 VUE 3.0L
Yes, the right rear clunks over bumps at times
Anyone here have parts PDFs? I could use the OEM part # for the rear springs
Old 07-31-2010, 04:32 PM   #4
ricksLS1
ricksLS1 has a spectacular aura aboutricksLS1 has a spectacular aura about
ricksLS1's Avatar
Looks just like the spring failure I had on my LS1 on the front. Mine had to be from the dealer and come in pairs. I think they were $250 for the springs. Maybe you can check some on line parts stores
ricksLS1 is offline   Reply With Quote
Old 07-31-2010, 06:24 PM   #5
ernesto rex
ernesto rex is on a distinguished road
ernesto rex's Avatar
My ALLDATADIY subscription is for the 2003 Vue, but I think the parts are the same.
Rear Suspension
Coil Spring
With AWD: 21990358
2000 LS2 (Sold, Sigh)
2003 VUE 3.0 FWD
2002 MINI Cooper R50
1978 GMC PU 7.4L
2020 Subaru Impreza
ernesto rex is offline   Reply With Quote
Old 08-02-2010, 09:47 PM   #6
1saxman
Most of the time springs just get worn out and sag, but sometimes they break. Put some new shocks in when you change the springs (always replace such parts in pairs) and the rear suspension will feel like new.
I would say spring breakage on the VUE is not common at all, but it can happen on any car at any time.
Old 08-09-2010, 04:32 PM   #7
300maximilien
2002 VUE 3.0L
Rear Suspension
Coil Spring
With AWD: 21990358
thank you. ended up grabbing a spring from a yard for $25 otd from a '03 with 50K miles
I installed new shocks last year and you are correct....rode like new.
Ended up taking about 1 hour to replace the spring.
Had to:
1. Jack up VUE
2. Place jack stand under frame.
3. Remove wheel
4. Place jack under lower control arm and jacked slightly
5. Remove bolt from bottom of shock
6. remove nut from bottom of sway bar end link
6. remove bolt + nut from lower control arm/knuckle
7. Carefully lower jack to release spring tension
8. decided to remove rubber jounce bumper to ease spring R&R
9. Reverse and torque to factory specs
Old 01-03-2012, 10:56 AM   #8
jcc007
jcc007 is on a distinguished road
2006 ION-2 Quad Coupe
Had to:
1. Jack up VUE
3. Remove wheel
Hi, I have a problem removing the sway bar end link because theres no room to get a air impact gun and it turns when I try to remove it. It's the Allen wrench one, which means I have to use a Allen wrench to hold it when I loosen the nut, but the problem is that the hole is so rusted the Allen wrench won't hold the bolt when i turn it. I'm thinking of grinding it off and replacing it with the new one I have. Any thoughts?? Took me 3 hrs to do one side of replacing because of that darn swaybar link pin!! Grrr
jcc007 is offline   Reply With Quote
broken coil spring scotttomlin S-Series Tech 14 07-17-2014 06:20 PM
Broken motor / trans mounts common? xfactor203 S-Series Tech 36 12-15-2009 03:29 PM
Broken Spring marmaduke L-Series General 7 07-10-2006 10:11 AM
Broken sunroof spring midnitebluSL2 S-Series General 0 10-20-2005 11:02 PM
Et Tu Broken Spring?!? LW2Rich General Saturn Discussion 1 05-23-2002 12:24 AM
