Old 10-03-2011, 04:21 PM   #1
Joshtheclockman
Joshtheclockman has a spectacular aura aboutJoshtheclockman has a spectacular aura aboutJoshtheclockman has a spectacular aura about
1994 SL
2002 SL
Default Service Engine light but no code
So here's something strange, I had my engine rebuilt last week and when I went to start it the service engine soon light came on. The mechanic told me that my oil pressure sender was causing it, but it couldn't be because i took that stupid thing out and put a couple of gauges in way before I had the engine rebuilt and there was no light. When i drive the car the light will go out when i reach a speed of 30-35 mph after the engine warms up to operating temp, and will come back on when the car sits at an idle and the pattern repeats, I put a code scanner on it and it didn't pull any codes from it. I'm at a loss, any ideas?
1994 Saturn SL 5speed 180290 miles, engine rebuilt 200 miles ago
Add to Joshtheclockman's Reputation
Rate the quality of this post and help Joshtheclockman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Joshtheclockman is offline   Reply With Quote
Old 10-03-2011, 05:19 PM   #2
Default Re: Service Engine light but no code
Don't let that "mechanic" near your car again. Or at least make sure he's read the FSM before dispensing any advice. The oil pressure sender (and/or the gauge sender you have in now) doesn't communicate with the PCM at all, so it can't possibly set the SES light.
You don't need a scanner to obtain the codes. For that matter, if your scanner is for OBD-II, that would be the most obvious explanation why it won't show any codes. With OBD-I, however, for the most part it doesn't store codes, so you can only obtain a code when the light is on. Visit our How-To Library, and search on "paper clip" for a way to obtain the code(s) using, you guessed it, a paper clip. So you'll have to carry one with you, along with the instructions, to capture it when the light goes on again.
Add to madpogue's Reputation
Old 10-04-2011, 12:01 AM   #3
Joshtheclockman
1994 SL
2002 SL
Yea I don't like the mechanic very much myself (if he really is a mechanic), that's why i generally do all the mechanic work my self. The scanner i used was a universal scanner and is supposed to be able to read codes from OBD 1 and OBD 2 as it has connectors and stuff for both and i told it to scan while the car was on but it still failed me, but i will defiantly try the paperclip, it sounds more promising.
Thanks!
Old 10-04-2011, 12:03 AM   #4
This is easier and the data is correct.
http://www.saturnwiki.net/index.php/..._Trouble_Codes
and
Old 10-04-2011, 12:06 PM   #5
Joshtheclockman
1994 SL
2002 SL
SO when i do the paperclip thing, is the cooling fan supposed to turn on when i turn the ignition to the on position?
Old 10-04-2011, 12:15 PM   #6
Joshtheclockman
1994 SL
2002 SL
Never mind scratch that, so i did the paperclip thing and i got code 12 and code 26
What is code 26 quad driver?
Old 10-04-2011, 12:31 PM   #7
PlasticCarsRock
PlasticCarsRock's Avatar
Code 12 just means the diagnostics is working. You should always get that code, even with the light off.
http://www.differentracing.com/tech_...es/dtc/26.html
from: http://www.differentracing.com/tech_...dtc_chart.html
from: http://www.differentracing.com/tech_articles/index.html
And yes, the cooling fan should run, when in diagnostics mode. That provides a way of checking the fan motor, relay, etc without jumping anything or waiting for the car to warm up.
Old 10-04-2011, 12:37 PM   #8
Follow this trouble chart.
http://saturnwiki.org/index.php/26_Q...r_Output_Fault
Use the links I posted above.
Old 10-05-2011, 06:24 PM   #9
Joshtheclockman
1994 SL
2002 SL
Thanks for the links, ill get a chance to look at the car on friday. I think i have narrowed it down to the EGR solenoid or the purge canister solenoid. Neither sound like fun to get to.
Old 10-08-2011, 04:49 PM   #10
Joshtheclockman
1994 SL
2002 SL
So after narrowing my search down the the egr solenoid or the puge solenoid, i was able to find the egr solenoid to find out it is still good. I cant find the purge solenoid. Do you guys know where i can find it?
Thanks!
Old 10-08-2011, 04:55 PM   #11
dbsanfte
dbsanfte is on a distinguished road
1999 SW2
Rear of the engine beneath the throttle body, no?
Add to dbsanfte's Reputation
Rate the quality of this post and help dbsanfte reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbsanfte is offline   Reply With Quote
Old 10-08-2011, 05:15 PM   #12
It is right above the starter under the #3 and #4 intake runners. Throttle body is close.
Old 10-10-2011, 02:47 PM   #13
Joshtheclockman
1994 SL
2002 SL
I found it and plugged it back in. I guess it was unplugged by accident when the engine was rebuilt, and it just didnt get plugged back in. The engine light is off now..
Thanks!
Service Engine Soon Light with P0133 Code LoganSan S-Series General 11 10-03-2010 04:57 PM
Trouble Code and Service Engine Light Big__Daddy General Saturn Discussion 1 11-10-2005 11:15 PM
Trouble Code and Service Engine Light Big__Daddy S-Series General 7 11-07-2005 08:05 PM
Service Engine Soon Light – Error Code P0133 Filo S-Series Tech 5 02-16-2005 04:49 PM
Trouble Code 49 on Service Engine Soon Light 93sl1 S-Series Tech 10 11-19-2002 11:19 PM
