Old 09-03-2019, 01:53 PM   #301
Default Re: S-Series Swap Guide
Axles:
http://www.saturnfans.com/forums/new...te=1&p=2295439
Originally Posted by PlasticCarsRock
From the factory, they are different, but the only difference is that the ABS axles have a reluctor ring (like a gear) for the wheel speed sensor.
As such, a non-ABS axle cannot be used on an ABS vehicle (the ABS wouldn't work), however, an ABS axle will work fine on a non-ABS vehicle.
There is a good chance many if not all aftermarket axles have the ABS reluctor ring (that way they don't need to make two different parts).
Originally Posted by OldNuc
The 91-93 axle does not swap into the later cars due to different splines on the outer CV hubs.
--The inner axle joint splines are the same from 91-02.
They will all fit into your transmission or onto your intermediate shaft regardless of trans type or brake equipment
--The axle shaft itself is 23mm thick for 91-93. It is 24mm thick for 94-02.
This goes for ALL the axles. ABS made no difference here.
The outer CV joint is where the most debate seems to happen.
--91-93 has a smaller spline diameter requiring the 91-93 wheel hub when using these.
--The 94-02 have a larger spline diameter, requiring the 94-02 hub.
Axles are not transmission specific. They are the same whether auto or manual transmission.
Generally, the right (passenger) axle for cars that came with steel wheels is the one most likely to break. These came with a rubber balancer to dampen vibrations on that side, apparently. Water and salt tends to collect under this, weakening the axle. If pulling from a junkyard, grab an axle from a car that came with alloys that does not have this ring. I never noticed a difference
see post 5 for how to select a good JY axle
http://www.saturnfans.com/forums/sho...d.php?t=137511
96 sc2... which years of window regulators will swap? not found in swap guide... DJboozeAlot S-Series Tech 3 08-07-2012 05:45 PM
i know theres the engine swap guide, but... KawaiiBoricua S-Series Tech 7 03-18-2008 08:00 PM
i read the swap guide lowwSC2 S-Series Tech 17 01-07-2008 11:57 PM
Swap guide richamer1 S-Series Tech 8 12-05-2007 11:01 PM
what happened to the swap guide 94503 S-Series General 1 05-14-2007 07:43 PM
