Old 04-13-2005, 11:04 PM   #1
n0n
n0n is on a distinguished road
Default Clunking Noise? (Control Arm problem?)
I've peered at the other clunking noises people have had, but I'm not sure if this is the same in my case.
Because this only happens sometimes, and I haven't found a way to re-create or force the "clunk", i'm just not sure.
On with the story.... Driving an Ion 3, 16" tires. So when I accerelate sometimes what will happen is this clunk, it happens sometimes in the middle of accerelation or when the car is shifting (automatic) from 1st to 2nd. It's hard to define the clunk it feels like i'm running over small bumps in the road, but the road surface is totally smooth. I have reason to believe it could be acorns and other tree debris on the road, coupled with the tires that kinda absorb all impact and releases it through the cabin. But dammit, I'm not sure, is there anywhere I should be looking at specifically under the car or what?
**I want to also add, this clunk, isn't like a transmission problem where the car is jolting, it just feels like a pop/bump/hiccup, and then it's over. And it's only from 1-20mph. It's audiable, I can hear it, sounds like it is right under me, but then again, what do i know?**
Thanks for the help, no other complaints about the ION. Actually I was pissed about the recall for the headlights, but when I went to get my oil changed, they said they already fixed the computer and headlight problem the last time I went. This was months before the letters were sent too.
Add to n0n's Reputation
Rate the quality of this post and help n0n reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
n0n is offline
03 ION Lower Control Arm Bushing Problem Red_Forman Ion General 4 06-30-2011 01:29 PM
Problem removing Lower Control Arm - PLEASE HELP... hydromech S-Series Tech 22 09-13-2009 05:17 PM
help removing control arm or control arm-to-frame bolt buckfu S-Series General 24 06-08-2006 01:26 AM
Hard breaking and steering problem - tie-rod, ball joint, control arm? MatthewWells S-Series Tech 10 09-21-2005 08:27 PM
My clunking noise is from the Driver’s side Control Arm not the sway bar bushings…. tbonejazzcat Ion General 3 04-12-2005 09:37 AM
