Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 05-25-2004, 02:28 PM   #1
ProDarwin
ProDarwin is on a distinguished road
Default Where to buy wheel spacers?
Anyone know where to buy some of these? 4x100 is a pretty common bolt pattern, so I imagine that someone would carry them for less than the $50 a pair sps wants.
-Travis
Add to ProDarwin's Reputation
Rate the quality of this post and help ProDarwin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ProDarwin is offline
Old 05-25-2004, 03:03 PM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default
pep boys?
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 05-25-2004, 04:21 PM   #3
Twin_Cam
Twin_Cam is on a distinguished road
Twin_Cam's Avatar
2000 SL2
Default
I imagine if it fits a Civic, it'll fit a S-series. There's TONS of Honda stores which are equivalent to SPS/Saturn.
'00 SL2m- DD, 186K miles
'05 Honda CR-V- wife's DD and my upright bass hauler
'84 Honda CB650SC Nighthawk- toy
Add to Twin_Cam's Reputation
Rate the quality of this post and help Twin_Cam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Twin_Cam is offline
Old 05-26-2004, 01:25 PM   #4
SIYAM
SIYAM is on a distinguished road
Default
If you have a first gen, the rear wheels are waaayyyyy in there. If you want real spacers let me know, but they aren't cheap at all. 25mm instead of 5mm. The 5mm ones are flimsy and don't really bring out the rear enough imho. With the 25mm ones, you will want to dial in slightly more front camber, though, to preserve your turn in. However, the rear will track out turns much better with the spacers. Check out my rear track, with small stock wheels and stock offset, and just 205 width tires.
Ian
http://www.qksltwo.com
Add to SIYAM's Reputation
Rate the quality of this post and help SIYAM reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SIYAM is offline
Old 05-26-2004, 02:28 PM   #5
shaung
shaung is on a distinguished road
shaung's Avatar
Default
Keep in mind if you buy non-Saturn specific spacers you may run into issues with the center bore. If the spacer's centering nose is a different diameter than the Saturn center bore, your rims may not center well, or not fit on the spacers. It can be worth it to purchase spacers designed for Saturn application.
Shaun
'03 Vue FWD4m 48K
Add to shaung's Reputation
Rate the quality of this post and help shaung reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shaung is offline
Old 05-26-2004, 08:11 PM   #6
ProDarwin
Default
These are for my 2nd gen. Sold the wagon.
-Travis
Old 05-27-2004, 01:32 PM   #7
eRic 02sc2
eRic 02sc2's Avatar
Default
another thing to consider is spacers take up some of the threads normal used for the lug nuts.
eRic 02sc2
Old 05-27-2004, 01:48 PM   #8
ProDarwin
Default
yes, but I know you can use the C4 Corvette studs to fix that problem.
-Travis
Old 05-27-2004, 11:35 PM   #9
rehm70
rehm70 is on a distinguished road
rehm70's Avatar
Default
www.wheeladapter.com
very good site, and immediate response, I was quoted 200 for two 2 " spacers for my ION, these are not just pieces of flat aluminum, they are a whole hub with an eccentric hub that your wheel fits over for a like factory fit, this is the strongest and least runout style of spacer.
Add to rehm70's Reputation
Rate the quality of this post and help rehm70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rehm70 is offline
Old 05-28-2004, 10:01 AM   #10
eRic 02sc2
eRic 02sc2's Avatar
Default
yeah, i got 16 corvette c4 studs in a box somewhere. i never did get around to installing them. i bought them for my 92 sc if that tells how long ago it was.
eRic 02sc2
Old 05-28-2004, 03:48 PM   #11
SIYAM
Default
Not if you use re-stud spacers.
Mine were around 120 and have their own studs.
Ian
SIYAM is offline
Old 05-29-2004, 09:05 PM   #12
Ian98SC2
Ian98SC2 is on a distinguished road
Ian98SC2's Avatar
Default
Where did you buy your spacers from Ian? I'm looking for some larger than 5mm spacers so I can fit some 225 R compounds with carrera coil overs. Currently with my 205 V700's and 2 degrees negative camber, its a tight fit...
Ian
Add to Ian98SC2's Reputation
Rate the quality of this post and help Ian98SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ian98SC2 is offline
Old 05-29-2004, 09:58 PM   #13
Applefool
Applefool has a spectacular aura aboutApplefool has a spectacular aura aboutApplefool has a spectacular aura about
Applefool's Avatar
2006 ION Red Line
Default
Ian.. Any idea how much drop that is in the above pic of your ride? Looks excellent.
2011 Audi TT (modified)
2007 Mercedes E550 (stock)
1999 Expedition (Stock)
2007 Ion Coupe (Daughters eventually)
Add to Applefool's Reputation
Rate the quality of this post and help Applefool reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Applefool is offline
Old 06-01-2004, 06:11 PM   #14
Garland
Garland is on a distinguished road
Garland's Avatar
Default
I have the exact same set of H&R spacers that Ian sells collecting dust (one set of 2 spacers, each is 25mm) that I will let go for 80 dollars + ship. I just need to get them off my hands because someone said they'd buy them through me, so as a favor I bought them, then they reneged and left me to shoulder the bill.
Anyways, they've been sitting around doing nothing. I hear you might have to machine out the center hub, but I cannot confirm or deny it.
I need to get rid of em so email me at midpennmotorsports@yahoo.com if you want it. If you want another set to match it let me know but they would go at full price (105 + ship).
Add to Garland's Reputation
Rate the quality of this post and help Garland reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Garland is offline
Old 06-01-2004, 08:10 PM   #15
Ian98SC2
Ian98SC2's Avatar
Default
I'll let you know on the spacers. I should be getting my 225's mounted later this week or next week. I want to test fit them first to see how much clearance I need.
Ian98SC2 is offline
Wheel Spacers (Anyone know where to buy) bumpdraft S-Series General 5 02-24-2008 05:58 PM
Wheel spacers - Possible group buy ub3rn00ber Ion General 4 11-10-2006 09:23 AM
wheel spacers defy69 Ion Mods 2 05-07-2006 09:04 PM
where to buy cheap hubcentric spacers for the LS? ghettoroadster Miscellaneous Tech 1 12-08-2004 11:25 PM
Wheel spacers SoCalSaturnsGuzzis Mods and Performance 2 05-23-2003 01:12 PM
