Old 10-20-2019, 07:38 PM   #1
Homecoming1999
Homecoming1999 is on a distinguished road
Default Cruise Control...another thread with questions..
Hi everyone, I know Cruise Control issues come up here and there and I have been reading... My Issue is the cruise control does not work at all in my 99 SL2 Homecoming. I checked the brake safety switch, it appears to be solid, fuses are good. Would it most likely be the Cruise Control module which attaches to the gas pedal? I seem them floating around on Ebay often..
Like others, the light does glow orange with the cruise is set to ON, just will not engage when set....
Do they really go bad frequently?
Cheers,
Jason
Add to Homecoming1999's Reputation
Rate the quality of this post and help Homecoming1999 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Homecoming1999 is offline   Reply With Quote
Old 10-20-2019, 07:59 PM   #2
laser3kw
laser3kw is on a distinguished road
2000 SC1
Default Re: Cruise Control...another thread with questions..
I would look at the steering wheel switches first. My left side cruise on (with light) / cruise off works good. The right side set / resume is kind of flaky depending on the temperature. I have to push it just right to get good results.
You may have to get a wiring diagram and intercept the connection somewhere to test it.
Add to laser3kw's Reputation
Rate the quality of this post and help laser3kw reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
laser3kw is offline   Reply With Quote
Old 10-20-2019, 08:15 PM   #3
trottida
trottida's Avatar
Jason, I have a cc module from a 99 SL2 if you need one. I can ship it to you or wait until my next trip to Toronto and drop it off. I don't know when that is though.
I was going to package it with a leather steering wheel and throw it up on eBay but I've been procrastinating for a couple years now.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Add to trottida's Reputation
Old 10-20-2019, 08:18 PM   #4
Homecoming1999
Thank you sir, so I guess my question is.....Is this a common failure part?
Old 10-20-2019, 08:26 PM   #5
billr
Does the horn work? If not, another suspect is the clock-spring.
Add to billr's Reputation
Old 10-20-2019, 08:40 PM   #6
Homecoming1999
Horn works great....as I said, I checked the brake safety switch, when my foot is off the brake I can see it making contact with the switch, it pushes in the little pin and I hear it click....
Old 10-21-2019, 10:54 AM   #7
trottida
trottida's Avatar
I wouldn't say it is common however I have seen occurrences reported within this forum.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 10-21-2019, 12:44 PM   #8
laser3kw
2000 SC1
this might be the best option. Kill two birds with one check
Another cruise thread WarWeasel S-Series General 1 06-23-2011 01:45 PM
cruise control install... problems & questions NO_SPRK S-Series Tech 22 11-20-2009 12:38 AM
Questions about Cruise control ii311hive S-Series Tech 2 06-22-2009 06:43 PM
Yet Another Cruise Control Thread - '04 Ion 2 WV6Z Ion Mods 0 06-03-2009 12:54 AM
Not another Cruise Control thread... ejafus Ion Tech 4 06-13-2008 11:29 PM
