Old 10-17-2019, 08:25 PM   #1
Rbernsdo
Rbernsdo is on a distinguished road
Default 1999 sl2 cluster lights/radio light??
Hey everyone, I just picked up a work car, 1999 sl2 5 speed with 90,000 miles on it. Stock everything, factory radio etc... when I picked it up I realized the cluster lights didnít work, so I pulled every single fuse under the hood and inside the car and threw new fuses in basically everything just because... there were none blown. That didnít help, so I bought a new dimmer switch, that didnít work, so I bought a new connector with the three wires for the dimmer switch, spliced it in, that doesnít work, I pulled the cluster checked every bulb, they are good... Iím not sure if itís related but the radio station light up screen on the factory radio only lights up when the lights are turned off, when I flip the dial to turn the headlights on, the little radio screen goes dark. Iím at witts end trying to figure this out. Does anyone have any idea what could be going on here?
Thanks,
Ryan
Add to Rbernsdo's Reputation
Rate the quality of this post and help Rbernsdo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rbernsdo is offline   Reply With Quote
Old 10-18-2019, 02:46 PM   #2
Default Re: 1999 sl2 cluster lights/radio light??
Welcome to saturnfans, and keep an eye on your oil level
(check oil at least once every gas fillup, the first few fillups)
It sounds like
  • your odometer works,
  • instrument panel (speedo, tach, etc.) works,
  • warning lights work (Service engine Soon, oil pressure, low coolant, etc)
Is that correct? If so, which lights don't work?
Did you check the two "theater" light bulbs? They provide most of the lighting for the gauge faces at night (gauges are not backlit) and they are easy to miss because of their forward position (not being on the back with the rest of the bulbs)
http://www.saturnfans.com/forums/sho...d.php?t=154888
It's possible that the previous owner damaged the cluster somehow. - pulled off a printed circuit or something
Radio power should be mostly separate unless the previous owner did something really, really odd (been know to happen occasionally )
Turning the headlights on is supposed to dim the radio readout (and odometer, IIRC) so that might be worth looking into
Do you see any splices in the stock wiring?
Might be something of interest in this thread
http://www.saturnfans.com/forums/sho...=136554&page=2
Old 10-19-2019, 11:12 AM   #3
Rbernsdo
Thanks for the response. All of the dash indications work fine. The lighting is the problem. There is no cluster lighting so I canít see anything at night.
Old 10-19-2019, 11:52 AM   #4
Waiex191
Waiex191's Avatar
We replaced the bulbs in our '99 because several were burned out.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Radio - Display light going off when lights are turned on. bigcougar L-Series General 3 04-19-2016 10:49 AM
Is it good to chang cluster lights with LED lights tecled S-Series Mods 2 03-22-2012 08:45 AM
Guage cluster lights, gear shifter light, and running lights not working. DracoAzule Ion Tech 1 12-11-2011 09:05 PM
gauge cluster lights light up when you hit the brakes! weird DJboozeAlot S-Series Tech 3 06-30-2009 03:56 PM
Light bulbs for the AC and radio cluster? turbobuick33 S-Series General 7 07-29-2005 06:36 PM
