Old 10-16-2019, 01:03 AM   #1
Fishfreq
Fishfreq is on a distinguished road
Default random high idle that is 'fixed' by turning off key, restarting...
Hey guys, just a shoutout, thanks, to all of you through the years that posted about the bad Throttle Position Sensor symptoms; I had random high idle, 1,200 to 1,700 rpms, no readily located leaks with carb cleaner, and if you shut the car off and restart it, normal idle would return, just for a while anyways. The high idle would also come down if you touched or wiggled the wires up near the TPS plug at the throttle body.
Went to AutoZone, picked up a $30 TPS, installed it, and for the last two weeks have enjoyed perfect running and idle! Thanks again guys, you know who you are...
Now I've got a starter gear that takes a sec to disengage after starting, so I hear a loud 'ZING' until it releases from the flywheel. I know, it's probably an easy fix, but another weekend project; check the spring strength, and solenoid for dirt interference, and clean it...?
Any recommendations on a good quality starter solenoid or do I have to replace the whole dang starter? Autozone?
Add to Fishfreq's Reputation
Rate the quality of this post and help Fishfreq reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Fishfreq is offline   Reply With Quote
Old 10-16-2019, 04:43 AM   #2
toggenburg
toggenburg's Avatar
Default Re: random high idle that is 'fixed' by turning off key, restarting...
You did not mention what car you are working on but if its a Saturn S series, then DBelectrical has the best starter for your car. Excellent product, free shipping and everyone I have from them has performed perfectly..
$51.47 delivered.
https://www.dbelectrical.com/starter...ive/saturn/sc/
Old 10-16-2019, 10:54 AM   #3
454cid
I'll have to try this with mine. My car will high idle sometimes too. It hasn't been bothersome enough to really fix, so far. I'm starting to suspect that it's effecting the downshifting of the transmission, however.
1999 Chevy K3500
Add to 454cid's Reputation
Rate the quality of this post and help 454cid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-18-2019, 02:04 AM   #4
Fishfreq
Mine's a manual, but I can only guess how it'd affect an auto! Mine didn't idle too much higher at first, put up with it for a couple months. Then it went up to 1,500 rpm, then 1,800. That was my breaking point...
Old 10-18-2019, 02:05 AM   #5
Fishfreq
$51.47 delivered.
Thank you for the good word Toggenburg!! Oh, mine is a 1998 SL1 SOHC.
Old 10-19-2019, 01:28 PM   #6
Fishfreq
$51.47 delivered.
See what I mean? Great answers to any saturn questions, you're very appreciated Toggenburg! Mine's a 1998 1.9 SL1 manual. Fun little economy car. When a starter gear stays engaged to the flywheel for a little bit too long, that's usually the recoil spring right? Do I need to replace the whole starter because of that?
Old 10-19-2019, 03:15 PM   #7
toggenburg
toggenburg's Avatar
Its your call, $25-30 for an autozone solenoid, or seeing you have over 170K on what might be the original starter, I myself would just spend the $51 and get a whole new starter from dbelectrical which will last you a lonnnnnnng time.
Old 10-19-2019, 03:55 PM   #8
The solenoid is built into the starter, I don't believe separately available to replace even if you have the know how. If it is available separately it'll be on DBElectrical's site and likely cost 60-70% of the new starter cost which includes the solenoid.
Might as well replace the whole thing since everything has to come out.
Old 10-19-2019, 05:29 PM   #9
toggenburg
toggenburg's Avatar
^^ not that I recommend replacing one, but they seem to be available for $20 for those somewhat inclined.
https://www.ebay.com/i/223272278632?...iABEgL9NPD_BwE
Random High Idle Ben2002SC2 S-Series General 7 02-09-2018 12:45 PM
Rough idle and random high idle Aaron K. S-Series Tech 35 04-26-2014 06:26 PM
Iacv fixed high idle now getting periodic low idle cmpcpro S-Series Tech 1 07-28-2010 10:18 PM
Random high idle johnny95sl2 S-Series Tech 4 07-02-2007 10:21 AM
Random high idle. brian.taylor S-Series General 4 01-10-2007 01:14 PM
