Old 10-15-2019, 10:46 PM   #1
98_Gold_Uranus
98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough98_Gold_Uranus is a jewel in the rough
98_Gold_Uranus's Avatar
Default Flickering fog lights
98 SL2
Last time I had my fog lights on, I was going through a drive though and happened to notice in the reflection of the bumper of the car in front of me that my fog lights were flickering... Not like completely shutting off, but dimming just a little for a split second. At random intervals... Best analogy I could say is that it looked like a lit candle when they flickered. They would do it, stay on solid for a few seconds, do it again, and back and forth, so on and so on. Headlights stayed solidly lit, it was just the fog lights.
Any suggestions on where should I start looking first to be the cause of this little issue? Relay? Button on the dash? Is there a common issue with these?
Not going to use them for the time being in case it's a short or something... I mean I would hope that at worse it would just pop a fuse if that were the cause, but you never know...
Thanks!
98 SL2, 70k miles, kept in the family since new!
Her name is Uranus :)
Add to 98_Gold_Uranus's Reputation
Rate the quality of this post and help 98_Gold_Uranus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
98_Gold_Uranus is offline   Reply With Quote
Old 10-16-2019, 06:28 AM   #2
toggenburg
toggenburg's Avatar
Default Re: Flickering fog lights
Presumably they are not LEDs, nor are the bulbs old, then I would inspect the both the socket for corrosion and / or the wiring leading to them.
Old 10-16-2019, 03:38 PM   #3
98_Gold_Uranus
They're just standard incandescent bulbs. The way they're flickering at the same time (together that is), I figured it's something in the main power harness leading up to them. But I'll check the plugs and connections at each bulb and see how they look.
Old 10-16-2019, 03:55 PM   #4
toggenburg
toggenburg's Avatar
Just last Saturday on my hay trailer, both rear turn signals stopped working, but did light up with truck parking lights ON.
I found both bulbs had burnt out the second filament at seemingly the same time. It must not have been a shorting issue, because with new bulbs they remain working correctly.
fog lights flickering singgirl17 S-Series Tech 1 09-15-2008 11:56 AM
Flickering lights? DWoofer S-Series General 8 11-28-2007 12:52 AM
Flickering Lights Ken A Relay Tech 8 06-09-2005 05:31 PM
Flickering Lights SliverXZennon S-Series General 11 03-02-2005 08:02 AM
Flickering Lights? CodisSL2 S-Series Tech 6 10-24-2002 07:42 AM
