Old 10-14-2019, 12:31 PM   #1
ilea
ilea is on a distinguished road
1997 SW2
Default Frankenstein's engine
I have a 99a ( no air injection) dohc engine with a bad block in my sw2 but good head and a 98 sc2 dohc engine with a cracked head (someone tapped the oil galley when replacing the a/c).
Can I slap the 99a head on the 98 block and call it a day or are the internals different? What about pcms/sensors? I wanted to do it the proper way and completely rebuild both the engines but I need a working car like yesterday, I'm in a bad situation and I'm kinda broke (obviously have enough cash for gaskets and a timing set).
Thanks in advance
<3
Add to ilea's Reputation
Rate the quality of this post and help ilea reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ilea is offline   Reply With Quote
Old 10-14-2019, 01:04 PM   #2
Waiex191
Waiex191's Avatar
Default Re: Frankenstein's engine
You have to keep the '99 valve cover. Possibly the intake and exhaust manifolds as well. Seems like it should work otherwise. I've got a 99 that I've rebuilt and a 98 that I haven't. Head bolts are torque to yield, so you need new ones. Not sure if the timing set is mandatory, depends on the condition. I'd replace it but if I was in a budget crunch and planned a rebuild later I'd skip it.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-14-2019, 01:13 PM   #3
Waiex191
Waiex191's Avatar
Check out the swap guide sticky at the top of the S-Series Tech forum. Confirms what I said.
Bryan Cotton
Old 10-14-2019, 01:21 PM   #4
ilea
1997 SW2
Thank you.
What about the timing cover? Are they all the same?
Old 10-14-2019, 07:17 PM   #5
Waiex191
Waiex191's Avatar
Check the swap guide. I'm not sure!
http://www.saturnfans.com/forums/showthread.php?t=88699
Bryan Cotton
Old 10-15-2019, 09:24 AM   #6
Timing cover to match the head.
Timing set to match the head.
Intake/exhaust manifolds to match the head.
Keep the wire harness in the recipient car.
TTY head bolts can be reused but it's safer to get new ones.
Parts Frankenstein questions jklein337 S-Series Mods 8 09-23-2017 01:56 PM
99 Saturn SL2 project (Frankenstein) samsr S-Series Tech 1 12-21-2007 11:48 AM
frankenstein S (mix and match parts) carl S-Series Mods 5 10-04-2006 01:19 PM
Frankenstein Motor? 944obscene S-Series Mods 143 09-20-2006 12:06 AM
Is my engine a Frankenstein? Ghostrider359 S-Series General 19 08-10-2005 02:26 AM
