Old 03-08-2019, 04:56 PM   #1
rgrafton
rgrafton is on a distinguished road
rgrafton's Avatar
2002 SC1
Default Looking for new wheels- let's talk size
I have a '02 SC1
I am looking to possibly get some new, bigger wheels. I want to fill the wheel well more. Something sportier. I mainly will use them during the warm months. I don't necessarily want to lower the car any, but may consider it. I know that going bigger on wheel diameter throws off the speedometer, but that's not too big of a deal to me. Once I know what 30mph and 60mph translates to I will just remember plus I have speedo on my gps.
I'm thinking of going with 16x7 wheels. 38-40mm offset. 205/60 tires. I assume it would fit if I didn't modify the stock ride height, but just double checking. Any suggestions/feedback/recommendations?
P.s. i'll probably keep the steel wheels and narrow 185 tires for winter
2002 SC1 5 speed 140k miles
1994 SL 5 speed 150k miles on engine (250k+ miles on car, tranny...etc.)
Add to rgrafton's Reputation
Rate the quality of this post and help rgrafton reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rgrafton is offline   Reply With Quote
Old 03-09-2019, 11:29 AM   #2
Default Re: Looking for new wheels- let's talk size
It won't be off by much if you "up size" to 215/50R16 (0.1" off), 205/60 is over 1.3" taller. Taller means slower, less fuel mileage and with that big of a sidewall it cant be much fun in the corners. If the speedometer isn't reading correctly the odometer won't be counting miles correctly either which has a big impact on the car's value.
Play around with size's here: http://www.rimsntires.com/specspro.jsp (note: the site doesn't check if the size you want actually exists, so you could come up with many many theoretical size's that nobody actually makes)
Stock tire size's:
175/70R14 (default on base model SOHC's, nobody using their head "options" it lol)
185/65R14 (not sure what it's default on, optional SOHC)
185/65R15 (default on SL2/SW2, optional on most)
195/60R15 (default on SC/SC2, optional most)
Various size's people have tried on their S-Series and what they did (if anything) to make them fit: https://sixthsphere.com/archive/index.php/t-72349.html
Old 03-11-2019, 01:45 PM   #3
rgrafton
rgrafton's Avatar
2002 SC1
Well it looks like I may lower my car at some point then!
I also do not like how the rear wheels as tucked under the car so much. I know that the 7" rims with 205s will help with that a little, but I was thinking spacers in the rear to get the wheels out more with the fender.. Anything against spacers? Any recommendations?
What is the easiest, most budget friendly way of lowering these cars? just a modest drop - maybe an inch or two
Old 03-12-2019, 12:21 PM   #4
The cheapest way to lower the car is to cut off a coil or two, but normal people find that too sketchy to run for very long.
The cheapest & safe way to lower the car is to get lowering springs. Ebaich and H&R make sets with 2" or 1.4" drops, the H&R part number is 54341 ($195 at TireRack).
Old 03-26-2019, 03:51 PM   #5
rgrafton
rgrafton's Avatar
2002 SC1
And I'd be ok using these springs with the stock struts?
Old 03-26-2019, 06:54 PM   #6
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
First, you need to understand what the numbers on a tire mean..
First number is tire width, 185 millimeters wide...
Second number is sidewall height, as a percentage of width, 60% of 185...
Third number is rim diameter, 15 inches...
Hence, a 205/60R15 fits on 15 OEM Saturn S Series rims, and is a little larger, but is wider...
Look at General RT43s in 205/60R 15, H speed rating.
You can inflate them to 44 for fuel economy, or 35 for ride comfort.
Mobil 1 ESP 0W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 03-26-2019, 06:56 PM   #7
mattwithcats
Tire calculator...
https://tiresize.com/calculator/
Old 04-15-2019, 10:49 AM   #8
SLfun
SLfun will become famous soon enough
2006 ION Red Line
I have 205/55/16's on alloys from a Saturn Ion. My car is lowered an inch and a half on H&R's. The tires are a bit too big but that's what the rims came with and they only rub turned all the way to lock and reversing. So I can live with that.
The perfect size would be 205/50/16 to replicate the stock tire OD.
My 96 SL2 and 98 SL1 have joined together to become one. So I guess I now have a 1996/8
SL1-2.
Add to SLfun's Reputation
Rate the quality of this post and help SLfun reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SLfun is offline   Reply With Quote
What size/bolt patter wheels for this car? Dave3 S-Series Tech 7 11-08-2012 07:12 PM
Let's talk wheels and fitment ilvtofu Astra General 3 11-19-2010 11:14 AM
Max size for Custom Wheels????? Redlinemsa L-Series General 5 02-06-2007 10:44 PM
what size wheels fit? coronaguy1211 S-Series General 10 11-26-2006 08:31 PM
What Size and kind of wheels to go with? Speed Mafia Ion General 1 05-10-2005 06:22 PM
