Old 07-26-2017, 12:32 PM   #1
GreenLine
GreenLine is on a distinguished road
Default Can I disable the hybrid system on an '08 Vue?
I have had a '08 vue for around 3 years. Only real trouble I have ever had out of it was a throttle body control sensor. If the hybrid battery was to ever go dead, could I just do away with it? I convert it to a standard 4cyl Vue basically?
Thanks!
Add to GreenLine's Reputation
Rate the quality of this post and help GreenLine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GreenLine is offline   Reply With Quote
Old 08-01-2017, 12:34 AM   #2
bern
bern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of lightbern is a glorious beacon of light
2004 ION-2 Sedan
Default Re: Can I disable the hybrid system on an '08 Vue?
If the hybrid battery fails to hold a charge then just replace the battery. Even if the price is north of 1100.00 ,
Reprogram BCM, ECM, IPC is not possible using the same VIN.
Add to bern's Reputation
Can you disable the theft system on a 00' sl2? chris015 S-Series General 5 08-30-2013 09:57 PM
EGR System Disable revisited KingRex S-Series Tech 7 02-05-2013 11:15 PM
2001 sl1 - any way to disable the security system? eriklane S-Series General 2 04-30-2012 11:16 AM
92 SC... removing driver airbag, how do i disable the SIR system? DJboozeAlot S-Series Tech 14 10-28-2010 06:50 PM
Tire Pressure Monitoring System - disable ? bjaspud Aura General 62 01-05-2007 08:57 PM
