Old 09-22-2015, 12:23 AM   #81
Default Re: 1996SL11.9L's 2002 SL1
Soak in Chem Dip until you can get the actual hydraulic adjuster apart and clean it out.
Old 09-22-2015, 01:14 AM   #82
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
I thought I had it apart that far. Removed the cap and clip, removed the inner piston and the spring underneath......I thought all I had left was the housing with the roller. The piston moves nice and smooth against the spring now.
Old 09-22-2015, 01:43 AM   #83
1996SL11.9L
2002 SL1
Only thing left to do is flush out the check ball hole with brake cleaner. If its possible.
Old 09-22-2015, 08:58 AM   #84
Soaking and flushing works. The inner piston of the actual lash adjuster will come out of there once the crud is dissolved. Chem Dip or Piston Clean and time is all that I found that will work. An ultrasonic tank and heat helps speed up the process.
Old 09-22-2015, 02:10 PM   #85
1996SL11.9L
2002 SL1
Did you see my picture on the previous page?
Old 09-22-2015, 05:40 PM   #86
1996SL11.9L
2002 SL1
I brought the rest of the lifters into work tonight. If I don't get slammed with trouble calls I may get the last 6 apart and cleaned out. A heat gun and air tool oil were very helpful.
Old 09-22-2015, 10:10 PM   #87
1996SL11.9L
2002 SL1
OldNuc, if the pictures upload is there more to disassembling the roller lifter than the 4 items pictured plus the top retaining clip?
Old 09-24-2015, 05:48 PM   #88
Back from road trip. Get a shot into both ends of the smaller cylinder. With luck it will post.
Old 09-24-2015, 07:22 PM   #89
1996SL11.9L
2002 SL1
Ok I'll take one apart again. Inside the small cylinder is a hole with a ball below it. From the bottom there is a cup that loos like it houses the spring pushing against the ball.
Hopefully here is a second picture I took with the small cylinder (piston?) on end.
Old 09-24-2015, 07:51 PM   #90
That is the ball check end and that has to seal tight. What does the other end look like?
Old 09-24-2015, 08:49 PM   #91
1996SL11.9L
2002 SL1
An open cavity That the cap sits on. Then held in place with the spring clip.
Old 09-24-2015, 09:10 PM   #92
What I want to see is the other side of the top and what the inside of the other side looks like. There are thousands of different adjuster designs, trying to ID the design.
Old 09-24-2015, 09:24 PM   #93
1996SL11.9L
2002 SL1
Ok it will be a day or so. There at the garage. The spring goes in the main body that the roller is pinned into. Then the piston goes in next and the check ball cavity goes inside the spring. I'll pull one apart hopefully tomorrow.
Old 09-30-2015, 04:30 AM   #94
1996SL11.9L
2002 SL1
Inside the hole of the lifter body and the piston.
Old 09-30-2015, 04:31 AM   #95
1996SL11.9L
2002 SL1
And since I can't do two pictures in one post. Here is the lifter body. Hopefully.
Old 09-30-2015, 07:58 AM   #96
Yes, thats all of it so soak in Chem Dip or Piston Clean until all parts are crud free and the check ball holds against a hard squeeze when it is all filled with any Xw-50 oil. reassemble with the 50 weight in them and let the valve springs squeeze them down to size, tighten rocker shafts slowly and evenly or they will break when doing this.
Old 09-30-2015, 01:25 PM   #97
1996SL11.9L
2002 SL1
Ok, still got some 50w lying around from the Harley oil change.
Old 09-30-2015, 01:42 PM   #98
Clean oil is required. The oil change rate in those is very slow so prefilling and ejecting the air tends to keep them clean for a long time.
Old 09-30-2015, 01:53 PM   #99
1996SL11.9L
2002 SL1
It's fresh oil. 15w50 and some 20w50 Nino oil lying around to.
Old 10-01-2015, 09:20 AM   #100
Either will work fine. Do not over fill as squeezing out excess takes awhile. After assembly of all rocker gear crank engine over 3 or 4 times by hand to get the process started or you will have valves trying to hang open.
2002 sc2 b.c.m. piperpilot S-Series Tech 2 11-12-2014 09:34 PM
2002 sl 1 Dee631 S-Series Tech 1 11-04-2014 05:36 PM
2002 SC2/Metra 70-2002 stereo harness issue Kai S-Series Tech 4 12-14-2008 03:41 PM
2002 SL1 Help Please reddragonflys20 S-Series Tech 9 11-21-2006 04:26 PM
2002 Sc2 Sps mle S-Series General 1 07-02-2005 07:33 PM
