Old 12-11-2010, 03:11 AM   #1
jiffypop
jiffypop is on a distinguished road
Default engine swap ? 99 sl2 swap in 98sl2
I have 98 sl2 with seized motor & mannual trans will a 99 sl2 engine be a plug & play swap?THANK YOU
Add to jiffypop's Reputation
Rate the quality of this post and help jiffypop reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jiffypop is offline   Reply With Quote
Old 12-11-2010, 11:14 AM   #2
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
Default Re: engine swap ? 99 sl2 swap in 98sl2
It will be pretty close. You might have to get an exhaust downpipe from another 99 (if yours is cut) and get it welded on. The 99s had a funky angle coming off the exhaust manifold.
If the 99 had an automatic tranny you'll want to swap over the flywheel and the flywheel bolts (these are longer than the flexplate bolts).
Consider a new water pump, thermostat, Engine Coolant Temp Sensor, clutch, and anything else you can see that needs attention while you're in there.
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Easier to Swap engine, or swap tranny? Saturn #4 S-Series General 6 03-21-2016 09:44 AM
Engine cradle swap; tranny swap MikeNW S-Series General 6 03-11-2015 01:04 AM
96 sc2... which years of window regulators will swap? not found in swap guide... DJboozeAlot S-Series Tech 3 08-07-2012 05:45 PM
96 SL1 w/ MP7 TRANS??? PLZ HELP!!! SWAP PCM FROM DOHC???? SWAP BOARDS??? randyshear S-Series Tech 20 11-15-2006 05:58 PM
Engine Swap or trannie swap SL-2er Miscellaneous Tech 1 04-28-2003 05:00 PM
