Old 06-03-2009, 07:38 PM   #1
jcar302
jcar302 is on a distinguished road
Default 03 l200 front hub/bearing replacement
I have a female friend with a 2003 l200, it's making a horrible bearing hum from the front P side. When i turn to the right (shifting the cars weight to the drivers side) the noise gets much quieter.
I'd be almost sure its the p side front bearing.
My main experience outside of brakes is with fords, and on my explorer (awd) the hub and bearing is all one assembly, so you buy it complete.
It would appear that on the saturn i will have to have the bearing pressed out and then in.
Is there anywhere to just buy a reman hub with new bearings in it complete? If it costs more that's ok.
If not, i could buy a press at harbor frieght if necessary, will a cheapo do the job properly?
Anyone know the size on the spindle nut? That seems to be the socket i'm usually missing from this type of project.
thanks,
Joe
1990 mustang 03 cobra engine conversion
http://www.youtube.com/watch?v=92hxg7Bg-5Y
2000 saleen explorer xp8 #30, supercharged 5.0
2003 L200
Add to jcar302's Reputation
Rate the quality of this post and help jcar302 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jcar302 is offline   Reply With Quote
Old 06-05-2009, 04:13 PM   #2
jcar302
Default Re: 03 l200 front hub/bearing replacement
Seriously, nobody here has had a bearing going bad on an L series?
Did i make this post in the wrong section or something?
2003 L200
Old 06-06-2009, 08:26 PM   #3
mudawg
mudawg is on a distinguished road
if your doing it yourself just get a new hub assembly, think autozone has them for like 150. Otherwise you will have to pay to get a new bearing pressed in
Add to mudawg's Reputation
Rate the quality of this post and help mudawg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mudawg is offline   Reply With Quote
Old 06-06-2009, 11:08 PM   #4
jcar302
I can't locate an entire hub at any chain store . Tried pepboys, advance, and autozone. None seem to offer a complete hub.
2003 L200
Old 06-07-2009, 01:09 AM   #5
Same basic proceedure as the S-series front bearings.
Add to ssicarman's Reputation
Old 06-07-2009, 11:15 PM   #6
mudawg
http://www.satpartswholesale.com/par...it_search.y=13
hopefully link works, looks like autozone doesnt carry front anymore just rear. www.satpartswholesale.com
Rear Wheel Hub/Bearing Replacement uhlemd Vue Tech 22 06-12-2016 02:17 PM
Front bearing/hub installation question Number6 S-Series Tech 5 03-19-2009 10:15 PM
front wheel bearing/hub assembly Cowboygrad04 Vue Tech 1 06-25-2006 09:19 PM
Rear bearing/hub replacement conefree S-Series General 18 01-11-2006 03:13 PM
Front Wheel Hub/Bearing Assembly JD7 Ion General 2 06-21-2005 05:52 AM
