Old 09-09-2013, 02:47 PM   #21
funnyfarm
funnyfarm is on a distinguished road
Default Re: 98 saturn sl2 just started running really rough
I have a 2001 saturn that had the same problem with same code. It turned out that my intake manifold gasket was leaking , causing a rough idle etc.
I changed the intake manifold gasket and every worked okay. Check it out
Add to funnyfarm's Reputation
Rate the quality of this post and help funnyfarm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
funnyfarm is offline   Reply With Quote
Old 09-25-2016, 11:06 AM   #22
ssbatarseh1
ssbatarseh1 is on a distinguished road
misfiring on multiple random cylinders...look at the ignition module under the coils. if cyl 1 & 4 OR 2 & 3 look at the coils.
Add to ssbatarseh1's Reputation
Rate the quality of this post and help ssbatarseh1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ssbatarseh1 is offline   Reply With Quote
Old 10-15-2019, 04:14 PM   #23
Rcola1111
Rcola1111 is on a distinguished road
I'd check the EGR pintle for carbon build up. Leaks there cab cause rough idle.
Add to Rcola1111's Reputation
Rate the quality of this post and help Rcola1111 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Rcola1111 is offline   Reply With Quote
2002 Saturn L100 running rough and trouble starting frankmassa L-Series Tech 7 10-20-2019 02:11 PM
1999 Saturn SL-2 Running rough and stalls at idle. Trequilo S-Series Tech 1 10-07-2011 04:53 PM
95 Saturn still running rough jammeger S-Series General 2 04-26-2008 02:49 PM
93 SL1 Running Rough Stinch S-Series Tech 5 09-12-2007 12:54 PM
95 SL2 just started running funny. oseberg S-Series Tech 8 08-28-2007 02:00 PM
