Old 10-14-2019, 11:17 PM   #21
PrestonIII
PrestonIII is a jewel in the roughPrestonIII is a jewel in the roughPrestonIII is a jewel in the rough
1994 SL2
1994 SL2
Default Re: P0340 code
If you're sure it's electrical:
Swap the 1-4 coil pack with the 2-3 coil pack to see if the problem stays with 1 and 4. If it stays with 1 and 4, then the coil packs are both good. You're possibly looking at spark plugs and wires, or an ICM failure. Try rerouting the spark plug wires to eliminate any cross-firing between 1 and 4.
Clear codes and swap the 1 and 4 wires at the coil pack (It will run). Start it, and see what codes you get. The coil packs spark both terminals at the same time; one with a positive voltage, and the other negative. This also suggests that you should verify all body and chassis grounds. Some Saturn's have been known to have poor grounds. Also, make sure the wires in the plugs from the computer wire harness aren't corroded.
You can also try swapping the 1 and 4 fuel injectors with the 2 and 3 injectors to see if that causes the problem to shift.
If after swapping coils, the problem moves, then it's the misfiring coil pack itself that's bad.
PrestonIII is offline   Reply With Quote
97 SC2 with code p0300 and p0340 isaiah38brown S-Series General 8 07-10-2016 11:43 PM
p0340 code dbaier S-Series Tech 1 02-22-2010 04:13 AM
P0340 ses code H-Dogg S-Series Tech 1 05-22-2009 03:08 AM
Still need help with P0340 code jegster S-Series Tech 7 07-01-2003 11:39 PM
SES P0340 code help jegster S-Series Tech 8 04-22-2003 09:45 PM
