Old 07-11-2017, 02:44 AM   #1
2008saturn
2008saturn is on a distinguished road
Default A/C blower motor
I have a 2880 Saturn vue,the blower motor works fine on the first start, after that it will sometimes work and sometimes not, I jumped the motor with battery and it worked fine, I also checked the plug at the motor with my volt meter, volts went down as I turned the speed up, I plugged the motor back in,still not working. Any ideas??
Add to 2008saturn's Reputation
Rate the quality of this post and help 2008saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
2008saturn is offline   Reply With Quote
Old 07-11-2017, 01:01 PM   #2
Default Re: A/C blower motor
Search threads about blower issues. At least two areas to be concerned about, ground and power wires. They may be burned with discolored insulation, possibly from loose connections. The blower resistor card controls all speeds other than high and hidden in the blower/hvac housing.
blower motor not working - getting 12 v @ motor until on djcrisco S-Series General 3 10-13-2015 08:01 AM
Need help with blower motor archonxx S-Series Tech 2 01-24-2008 12:11 AM
help with blower motor hkusp S-Series General 3 06-11-2007 09:26 PM
Do i need a new blower motor? striker1211 L-Series General 5 11-24-2006 10:49 PM
HVAC Blower Motor Dying...can one fix motor? flyhop S-Series Tech 2 09-28-2006 10:08 PM
