Old 10-18-2018, 07:11 AM   #1
54packman
54packman will become famous soon enough
1998 SW2
2000 SC2
Default Engine swap
Quick question, can a single cam engine be replaced with a twin cam engine without changing the PCM, I just spun a bearing in the bottom end in a single cam sc1, and know where there is a good twin cam motor... or do I have to switch heads over?
Add to 54packman's Reputation
Rate the quality of this post and help 54packman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
54packman is offline   Reply With Quote
Old 10-18-2018, 08:12 AM   #2
Default Re: Engine swap
If you never go above about 75% throttle it'll be fine, otherwise the SOHC PCM's idea of full throttle fueling will go lean on the DOHC and burn up valves.
Depending on year swapping the PCM is a 'bolt-in' affair and unless prices have changed they're pretty cheap (under $70).
Old 10-18-2018, 08:44 AM   #3
54packman
1998 SW2
2000 SC2
ok thanks, I can see if I can also find a pcm for the twin cam motor as well too
Easier to Swap engine, or swap tranny? Saturn #4 S-Series General 6 03-21-2016 09:44 AM
Engine cradle swap; tranny swap MikeNW S-Series General 6 03-11-2015 01:04 AM
Engine swap help. Can you swap without taking off the transmission? 99 sl2 5-speed msmay0 S-Series Tech 5 06-10-2012 05:01 PM
engine swap ? 99 sl2 swap in 98sl2 jiffypop S-Series Tech 1 12-11-2010 11:14 AM
Engine Swap or trannie swap SL-2er Miscellaneous Tech 1 04-28-2003 05:00 PM
