Old 10-16-2018, 11:09 AM   #1
Cavell
Default control arm noise
have a rattle over bumps. my street is downhill and as i pull into driveway i get a good click/clunk from driver side lower wheel well area. i have a new balljoint and control arm bushing on that side. both parts looked ok when i replaced them. i have new sway bar links. bushings look good. noise is present even when i removed links. i have new front struts. strut mounts looked great. i did not changed them. checked innner/outer tie rods. they are tight. had rig on 2 lifts and 2 techs looked at it. both said wheel bearings are fine. i pulled both calipers apart and the pins/bushings are good. i could change the strut mount for giggles. and than the wheel bearing? any ideas?
Add to Cavell's Reputation
Old 10-18-2018, 03:27 PM   #2
What a VUE
What a VUE is on a distinguished road
What a VUE's Avatar
Default Re: control arm noise
It's likely the strut mounts themselves. They can look fine and still be bad.
You've eliminated everything but that, as far as I can see.
Dave
07 VUE 3.5 AWD
Add to What a VUE's Reputation
Rate the quality of this post and help What a VUE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
What a VUE is offline   Reply With Quote
Old 10-22-2018, 09:05 AM   #3
Cavell
i did check the cv axle for play. the inner joint has a loud click when you rotate it for/rev and i believe it is from inside the diff side cover. i see many video's online showing the issue and almost all say its normal. well, some do show up/down movement and the poster says they got a new trans and all is well. but i think that is not common. strut mount it is. cheap. and i know how to do it as i did the struts myself
Old 10-26-2018, 08:54 AM   #4
Cavell
mount is being delivered today. i will find out if my current mount which appeared ok is the culprit.
Old 10-28-2018, 11:42 AM   #5
Cavell
new mount fixed the noise. i noticed the old mount had a rubber layer bonded to the plastic spring seat. new mount is all plastic. i noticed many mounts online are also plastic. hard to discern detail in black/white pics from vendors. almost have to inspect them to see if some do have rubber layer
Temp control - Noise paulff3 Astra Tech 2 12-28-2012 08:11 PM
ABS/Traction Control making noise Badman Aura General 7 01-12-2010 01:08 PM
Ion Noise/Control Problems Cured! L200INRI Ion General 14 05-23-2006 02:00 PM
Clunking Noise? (Control Arm problem?) n0n Ion General 0 04-13-2005 11:04 PM
Cruise Control Noise??? korax123 Ion General 8 10-17-2003 04:06 PM
